Hey guys, i'm having a weird problem with an au2 i just bought recently. Basically every now and then when i hit the accelerator from a standing start, i get some shudder from the rear wheels.
My brother says that he can see some smoke coming from the exhaust which makes me think it may be dirty injectors or faulty sparks??? I'm not that great with engines and don't have he right tools, so the best i can do is pull the leads off and they seem to be alrght. Is this a normal problem with the au series??? As i said, i just bouht the thing and haven't had a chance to have it serviced properly. Thanks in advance for any help/suggestions |
With da Warlords
its normal for an au to smoke for a split second when you start it and/or get into it, if its cold. Because of the rich mixture, when its operating closed loop mode while warming up.
It should not smoke any other time though.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
![]() Last edited by james22; 28-09-2006 at 01:03 PM. |
its your plugs and leads.
a friend had the same prob and thats what he changed and its all good
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
