08-11-2009, 01:56 PM | #1 | ||
hey guys
my platstic wheel arch ripped off a few months ago and i found this behind there, front left hand side wheel arch, now i have no abs in the engine bay but have this, can any one confirm if any one can confirm please
08-11-2009, 01:59 PM | #2 | ||
I'm pretty sure ABS was standard on most AU's?
08-11-2009, 02:01 PM | #3 | ||
ABS unit sits next to the fuse box on the drivers side. That there looks like the Horn and the Aircon piping.
I should also add that in your photo the ABS unit is missing, so sadly, no, you dont have ABS.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project Last edited by broken_suave; 08-11-2009 at 02:08 PM. |
08-11-2009, 02:05 PM | #4 | ||
isnt it 2 lines you have abs, 3 lines you dont, my horn is behind my front support bar no where near there
08-11-2009, 02:05 PM | #5 | ||
as monty said in your other thread, no ABS on S1 Forte
08-11-2009, 02:06 PM | #6 | ||
thats not abs.thats your CHARCOAL CANISTER.
08-11-2009, 02:06 PM | #7 | ||
Now Fordless
That is the fuel purge solenoid.
PS. fill up your coolant and washer bottle : |
08-11-2009, 02:09 PM | #8 | ||
its a series 1, thanks guys, might have to get a new cover, by the way, how do i remove them to change them over, looking shaby
08-11-2009, 02:11 PM | #9 | ||
Just to add to my above post, the ABS unit is missing from your photo above, so sadly, no, you dont have ABS.
79 P6 LTD Silver Monarch - Project |
08-11-2009, 02:13 PM | #10 | ||
not a worry tho pulls up just fine when i slam the brakes, no problems, thanks guys, ps, how do i go removing the plastic inner guards and replacing them
08-11-2009, 02:14 PM | #11 | ||
Has anyone noticed that the Coolant reservoir tank has no low coolant sensor? I thought the series 1's had them and 2 and 3 didnt? Maybe its a series 1.5?
08-11-2009, 02:16 PM | #12 | ||
thats a old pic, done a top up and a service before i went to stanphorpe cheers
so any ideas on how to remove them, might as well replace them while im no doing anything
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors Last edited by frd906; 08-11-2009 at 02:19 PM. Reason: rong post |
08-11-2009, 02:18 PM | #13 | ||
shes a feb 99 build
08-11-2009, 03:11 PM | #14 | |||
Now Fordless
08-11-2009, 03:52 PM | #15 | ||
no worrys cheers
09-11-2009, 09:18 AM | #16 | |||
gone fishing
Cheers Whiskers |
09-11-2009, 09:22 AM | #17 | ||
i no i have a fluid warning light on my cluster, so when its only has pure water in it no coolant it shows up on the dash
09-11-2009, 09:45 AM | #18 | ||
Just another mock-up..
so the light comes on only if you have water that has no coolant in it yeah...?
is that what you're saying..? hmmmmmm???
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
09-11-2009, 10:30 AM | #19 | ||
I hate to throw the thread off track, but it seems the original question has been resolved.
I have an early series 1 and I have a low coolant sensor in my reservoir. However I have seen a few series 2 and 3 engine bays and I have seen no sensors in the reservoirs. I was wondering if 906FRD had a 'Series 1.5' ie: the series 1 update. Does anyone know definitively which cars have the sensor in the reservoir and which cars dont?
09-11-2009, 10:58 AM | #20 | |||
Shame Holden, Shame
Usually only fairmont and + has the sensor.
Essendon FC '11 EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer| METALLICA |
09-11-2009, 12:24 PM | #21 | |||
light which comes up on where the speedo is, shows a lil pic wits a x in the middle of it, have a look up in your ford manual, it tells you right there
09-11-2009, 12:25 PM | #22 | ||
mines a 99 feb build
09-11-2009, 12:32 PM | #23 | |||
09-11-2009, 12:33 PM | #24 | ||
All Bran = Regular Member
My Series 3 Fairmont Ghia doesn't have the sensor in the reservoir.
I assumed that is because it will shut down cylinders in an overheating event? |
09-11-2009, 04:50 PM | #25 | |||||
The low level coolant sensors are on all cars. I have a S2 ute and the only reason it has the sensor in the reservoir is because i added it to go with my XR dash cluster.
Also, Kristo was asking whether the sensor picks up the difference between water and water/coolant, which it doesn't. Please read all posts thoroughly before responding
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
09-11-2009, 08:54 PM | #26 | |||
09-11-2009, 10:54 PM | #27 | |||
growing up is optional
You have hit the nail on the head without even knowing it. Some Series 1 AUs had a drama with the coolant level light coming on from time to time on vehicles not equipped with this function or sensor. A fix that Ford tried for a while was to fit sensors to them. It never really worked properly. After that they had us removing the 'loop' fitted to the unused coolant sensor connector on the loom and earthing one of the wires. From what I can remember, this fixed the problem. |
10-11-2009, 12:28 AM | #28 | |||
Lost Boost Gained Class
i have a Dec Build S1 Forte and its got ABS and Cruse Control and a Low Coolant Sensor i know this as its gorn off and its on the side of the bottle
2006 BF Fairmont Ghia
2001 AU Falcon |
10-11-2009, 11:22 AM | #29 | ||
i have the crusie controll and the low level coolant light fitted to mine, i no this as well as its come up before,
but i dont have abs, dosent matter anyways, stops good enough for me
10-11-2009, 11:53 AM | #30 | ||
I miss my wheelbarrow
Havent read the thread but I just have to add.....
Lift your shirt and check for 6 or more bumps on your stomach region. If you have these you most likely have Abs. Daniel |
