hi ppl
will a EB 5spd conversion kit fit into my EL faimont ghia, will i need to change anything to make it fit. and what do i need to do to the ECU to make it run thanks Nick
FG XR8, 6spd auto, dual zone, sat nav, camera, leather, k N filter, Quad exhaust. |
#2 | |||
The box, clutch, pressure plate, flywheel, etc fits no probs.
The pedal box is different, but can be made to fit with an angle grinder
#3 | |||
![]() Join Date: Dec 2004
A 5 speed EL Ghia would be pretty sweet and unique. Wouldn't there be ECU issues?
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
Last warning
any EL 5 speed ECU would do the job, neonick has a 5 speed NL fairlane
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() Last edited by EFFalcon; 10-07-2005 at 08:37 PM. |
#5 | |||
Well that's handy to know if I ever kill the BTR in mine ;)
Last warning
Not sure what you have to do to the Auto ECU to make it work, should be plenty of people around that would know
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Theres just the issue of the xr mtor and if you wanted to retain the xr ecu. you need a high series ecu to control the fan blower speed because the low and high series work oppisite to each other.
Last warning
isnt that BEM related and not ECU related?
look at page 10-1-37 of the manual. pin 86 low series, high = 12v low = 0v, high series high = 0v, low = 12v
then page 21-2-40 theres definitly a link from the eec to the fan motor control.
i was told i need to ground the S5 wire form the ecu to earth but im not to sure yet if thats right or when i get the unichip will that fix the ecu probs?
and will the crossmember from the EL bolt up to the 5spd? thanks Nick
#11 | |||
Use the EB 5 speed crossmember.
I used my auto crossmember but had to redrill the mounting holes.
#12 | ||
Smash the Boost
Do you have speed sensitive steering? You will need to keep the auto ECU if u want to retain this feature (assuming the Ghia's did have it)
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
#13 | ||||
