03-12-2009, 05:59 PM | #1 | ||
Im replacing my NOS big shot plate with a ZEX perimiter plate, i know NOS brand jets arent suitable but need to know will the ZeX jets fit into the -6 lines that are supplied with the NOS big shot kit??
Tyres are evil and must be punished |
04-12-2009, 07:21 PM | #2 | ||
Don't the jets sit inside an A/N fitting? Nothing goes in the line itself. It depends what size line is run with the zex kit. If it is a dash 4 line then use a speedflow Dash 6 to Dash 4 reducer. If the zex plate uses A/N fittings then yes the Dash 6 line will fit somehow.
05-12-2009, 03:27 AM | #3 | ||
Im worried about the ZEX jets not being compatible with the an fitting, ive heard they are dimensionally different from the NOS brand jets but not sure if they mean flow wise or outside dia. wise
05-12-2009, 10:22 AM | #4 | ||
You would assume that they mean flow rate as all nitrous kits are built with commercially available A/N fittings used. All commercially available A/N fittings are interchangable with the same threads and I/D's used. The O/D's, external appearance and the internal flow characteristics are the only variances better different brands of fittings
05-12-2009, 01:33 PM | #5 | ||
Found this at Summit
"If converting your NOS® or Edelbrock® plate system to the ZEX™ Perimeter Plate, you will need to purchase ZEX™ compatible jets in the sizes that NOS® and Edelbrock® recommend for the plate you are replacing."
06-12-2009, 07:11 PM | #6 | ||
Thats a good result. You only have to buy different jets
06-12-2009, 09:09 PM | #7 | ||
Perhaps, but can only find ZEX jets up to a 175 shot
08-12-2009, 01:25 PM | #8 | |||
If it aint Blown it Sucks
That will give you more ! perhaps the plate can't flow more than 175, or the solenoids etc don't forget the plate also has to flow the fuel as well.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph @235 rwkw !! Now turbo 11.77 @114 mph 320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds: Now for sale http://www.fordforums.com.au/showthread.php?t=11296772 Thanks to Snort Performance, Headsex and CVE Street car DeTomaso Pantera Drag car 1995 Mustang, Haleys Comet ( It's back !) Power by CVE Melbourne's first SNIPER Tuner : Now tuning E series |
