Old 13-03-2010, 12:20 AM   #1
soulink
Default Rearview mirror vibrate help!!
Hey guys,
just an enquiry as to how any of u have stoped ur rearview mirror from vibrating with a sub?
Any suggestions would b sick
thanks
soulink is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 12:27 AM   #2
GS608
turn the sub down? lol
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 12:29 AM   #3
TheInterceptor
Cruising...
TheInterceptor's Avatar
Dont think its possible, everything shakes regardless... Mine does it aswell
The vibrations travel through the car pretty well... maybe the others know a way Oo
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 12:32 AM   #4
TheInterceptor
Cruising...
Lol mine did it without a sub Not as bad though
Old 13-03-2010, 03:19 AM   #5
Mechan1k
Mechan1k's Avatar
Turn the sub up and the ball joint in the mirror arm snaps ... like what happened to me in my last ute.
Then you get rid of the rattle that way
Old 13-03-2010, 09:32 AM   #6
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
i had my mirror fall of the windo the glue gave way one min it was there the next it was gorn
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 10:11 AM   #7
DaveTE
Back in black
DaveTE's Avatar
New mirror can lessen it but not stop it. Mines starting to move around during general driving in the T so times for a new one.
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 10:28 AM   #8
GK
Walking with God
GK's Avatar
Had this issue myself recently, and it's not the first time on the S2. The S1 has never had any issues, as the mirror is held onto the window metal by a small Allen Screw.
S2 they went a cheaper route. The metal base (which glues to window) is a different shape, which is annoying as I tried to put a S1 mirror onto the S2 base, but alas no joy!
If you have a S2-3 and the mirror base falls off the glass, replace the whole lot with a S1 setup, that way you shouldn't have the vibration issues.
The Reason:
The S2-3 mirror just slides on the base with no screw to hold it firm. Over time, the metal rail on the mirror itself loosens as it loses tension. the actual rail (clip) is only held to the mirror with two rivet type thingy's!
The Potential Fix:
1. New Mirror!
2. Use epoxy glue or similar to apply to these rivets to stop the metal rail (clip) from moving around.
the first time it happened to me (a few years ago) I replaced the mirror. A few years later on (two weeks ago) it's started again and I tried the epoxy solution.
The Result:
It's heaps better, but not as good as when I replaced the whole mirror.
If you choose to get one from a wreckers, look carefully at the metal clip and the two rivets. If there's any movement, get another.
If you get a new item, SWEET!
A Thought:
It might be possible to actually drill out the rivets and try to use small screws to reattach the clip/rail, but there doesn't appear to be too much mirror material to actually screw them into. If you're going to get another mirror, I guess it's be worth a go though. Nothing to lose!
Another Thought:
If there's a chemical you could apply to the windscreen to dissolve the glue holding the mounting plate, so you could get it off undamaged, you could replace the whole lot with the S1 setup.
Anyone know of such a product?
Hope this helps.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-03-2010, 10:37 AM   #9
The Monty
Just slidin'
The Monty's Avatar
I just sit my wallet on top of it, it stops the rattling. Just watch out when you are going around corners.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 10:43 AM   #10
DJM83
Barra Turbo > V8
DJM83's Avatar
Good write up GK, mine does it in the TE w/o a sub and general driving.
2011 XR6 Turbo Ute
- Manual
- Lux Pack
- Twin 2.5" Stainless Exhaust
- Antz Turboside Intake
- CCForged Phatlux wheels
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 01:29 PM   #11
POELWYK
POELWYK's Avatar
well mine is a S1 and it and shakes like crazy ill upload a vid
but mine dosent make sounds like Trist one dose mybee because i got a S1 and he has a S2 but mine shakes and stuff his is just anoying
i like GK's idea replaceing it with a S1 one
http://www.youtube.com/watch?v=xd5Tu2zlu0U
2001 AU Falcon
Old 13-03-2010, 01:44 PM   #12
fourl6
AU Falcon Man
fourl6's Avatar
i put some bluetack in the ball joint between the actual mirror and the stalk...
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2010, 02:27 PM   #13
soulink
lol ok ill try that but yer it isnt just a shake its a massively loud vibrating rattle lol
Old 17-03-2010, 06:44 PM   #14
GK
Walking with God
GK's Avatar
That's what I'm getting, although not massively loud, it is rather annoying! Try the glue, then if that doesn't work, perhaps it's time for a new mirror.
GK
Now gone!
On LPG
Old 17-03-2010, 11:56 PM   #15
superroo
You can't stop the signal
superroo's Avatar
Originally Posted by GK
Another Thought:
Mainly acetone comes to mind, but paint thinners may work as well.
Old 18-03-2010, 10:11 AM   #16
GK
Walking with God
GK's Avatar
Thanks Roo.
What's the state of play with the ute? Have you been able to get a quote from one of those joints that removes dings?
GK
Now gone!
On LPG
Old 18-03-2010, 06:42 PM   #17
V3RSAC3
... Fear it!
V3RSAC3's Avatar
My outdoor ones shake with a stock system ... Im often "how quick is that car comming?....oh wait"
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2010, 01:16 AM   #18
Pepi69
PEPI69
Pepi69's Avatar
hi,
I don't have a sub in my car, but I found since having really stiffened up my car's suspension - my rear view mirror used to vibrate while driving. I went to Clarke Rubber and got a piece of 1mm thick/5cm wide/1 foot length of rubber. All I did was cut a couple of pieces of this rubber and slipped it behind the mirror mount itself where it would 'slip' in - doesn't vibrate as much any more....if that makes sense.
aims to please.................
Pepi69 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2010, 06:47 PM   #19
robbyj
Rob
robbyj's Avatar
Yea mine shakes pretty bad (S1) i tried tightening up the screw on it, helped for a bit, although i reckon it has shaked loose again. Havnt found a fix, good thread tho, at least you know your not the only one =p
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2010, 10:38 PM   #20
urbancowboy
Seems as though this is a common prob! mine vibrates too with stock non premium sound and no sub, as does the external drivers side mirror, i was thinking of replacing the internal mirror when i get a new windscreen now i think i'll have a look at the S1 version. Cheers
urbancowboy is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2010, 03:27 PM   #21
skelly
skelly's Avatar
Hey guys,
thanks
hahaha who dont have this problem, i wrapped a bit of duct tape around the passanger side end of the mirror tight, but then when it stopped i noticed all my fan things atarted vibrating aswell. just need to get used to it
skelly is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2024, 10:07 AM   #22
shaggyward
shaggyward's Avatar
Default Re: Rearview mirror vibrate help!!
Add stick on wheel weights to the top of the mirror, this has worked on my AU2 for the last 15 years.
Mk 1 Cortina coupe
Mk 1 Cortina sedan
TE Cortina 250 xflow Gl
XE Falcon wagon Gl
KE Laser wagon Gl
EB Falcon sedan Gl
AU 2 Futura wagon
SZ Territory Titanium
shaggyward is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2024, 10:46 PM   #23
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Thread mine but good idea.
Uncle_Ken is online now   Reply With Quote Multi-Quote with this Post
