17-03-2015, 10:16 PM | #1 | ||
au2xr8 ute
Was wondering if anyone could help
Have got a crane cam 2031 in my ute yellow terra 'street terra' roller rockers and having trouble with clearance on the factory rocker covers does anyone know of a part number of tall rocker cover that will fit efi engine because of the manifold? |
18-03-2015, 05:20 PM | #2 | |||
AU DIE HARD
Need to get a phenolic spacer for it ,lifts the inlet manifold up , various sizes 1/4" usually does it or if it just touches it double up on the cover gasket
18-03-2015, 09:30 PM | #3 | ||
Peter Car
Are your referring to the rockers touching the valve covers? Some roller rockers will touch, you can usually just give the oil filler baffle a bit of a bashing to create the clearance required.
18-03-2015, 10:26 PM | #4 | ||
au2xr8 ute
Yeah doubled on the gaskets and done a bit of modifying on the covers where they were hitting but wanted to change to a taller one just for peace of mind really plus will look a lot better than the factory windsor ones thanks for the replays
18-03-2015, 10:27 PM | #5 | ||
au2xr8 ute
