16-01-2017, 08:17 PM | #1 | ||
Not often I remove the oil filter without spilling some so last time I put a plastic bag over the filter before removal. Use caution with hot oil.
17-01-2017, 01:48 PM | #2 | ||
Irregular member
Such a simple idea to save a lot of mess! Thank you!
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
18-01-2017, 07:27 PM | #3 | ||
Good tip. Another is with an upside down filter (where thread/seal face the ground and back of filter body faces up) is to use a screwdriver to punch a few holes in the top and leave it to drain dry whilst you drop the oil in the sump. By the time it's drained and finished dripping the filter should be dry and come off without dripping oil down it's mounting adaptor.
18-01-2017, 07:56 PM | #4 | |||
19-01-2017, 11:25 AM | #5 | ||
vbvbvb088
Plus I place oil filler cap in bonnet latch grille area straight off so u cant close bonnet..reminder to put oil in.
3 users like this post: |
19-01-2017, 01:42 PM | #6 | ||
While we are on the subject of oil tips... Here's one for the dipstick ...
http://www.fordforums.com.au/showpos...&postcount=106 |
19-01-2017, 02:18 PM | #7 | |||
Better to put the keys well away from the car while working on it, so you can't start it inadvertently in the meantime. |
19-01-2017, 05:51 PM | #8 | |||
vbvbvb088
19-01-2017, 06:57 PM | #9 | ||
BLUE OVAL INC.
I use a coke bottle, just cut the bottom off and then a section out of one side then loosen the filter, slip the bottle up over the filter and continue to turn it via the cut out section and all oil and filter will drop down into the bottle.
Then I undo the bottle lid and let it all drain out into an empty oil bottle from a previous service and its all good. Then I just bag the filter at the end. |
19-01-2017, 10:56 PM | #10 | |||
20-01-2017, 12:10 AM | #11 | |||
Some cars have neat little holes drilled to indicate min/max. With the FG I've always angled it to get the reflected light off the shiny oil, and when holding it at this angle, the cross-hatching is quite clear - but I do have good eyesight (with glasses on). |
2 users like this post: |
20-01-2017, 02:06 AM | #12 | ||
Yep...I'm waiting on my glasses atm (long sighted) and all of these fiddly things are now a pain. This is a great idea. You reckon the Ford sticks are bad, my wifes Subaru's stick is one dark colour with tiny holes drilled in it. two high & two low holes on the stick. A more contrived reading I couldn't think of.
