hey guys as it states i just bought an AU11 XR8 how do i tell the differance between a 200KW and a 200KW? and they said its SVO enhanced how can i tell? it has a SVO badge on it.
would any1 be able to help me? cheers brendan |
Check throttle body. 220kw had tickford wings engraved on the trottle body where as 200kw didn't.
Giddy up.
So many off the 220kw add on's could have been added by prevoius owner/s, your best bet would be to ring Ford with the vin and get the correct info.
Wanting a sprint!
please correct me if im wrong, but didnt ford just kit up a standard falcon to make them like a xr and name it svo?
On track for mint turbo falcon |
#5 | |||
AFF's 1st DM.......
No SVO is mick webbs speciality
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
#6 | |||
AFF's 1st DM.......
Damn there also was a series run of EL falcon XR8's with an ELGT kit with the same engine hardware, but the interior was remarkably better ie leather embossed seats etc.
not here much anymore
as said above, SVO is an aftermarket operation - they have no links/ties with Ford at all. If you wanted to find out what they did to the car you would need to call them, theyre in Melbourne (somewhere). Mick Webb's SVO is the full name of the company.
Your best bet to tell if its an AU 220 or not is to ring Ford with the VIN number - 13FORD is the phone number. Throttle bodies etc can all be changed.
RAM 1500
#8 | |||
#9 | |||
AFF's 1st DM.......
If hes done the work mate, it should all be logged
#10 | |||
RAM 1500
ok sweet i think ill call em n ask. hopefully they can tell me..
thanks alot guys.. cheers brendan |
#12 | |||
MoPar man 11
Gazza |
formerly "3x-puursui7"
their on the very top of the t/b facing straight up.
did the 200's gt the bigger t/b but without wings? cos im sure all S2/3 utes came with 200's except for the pursuit..... you may have a rare beast if it is a 220!
all hail the mighty V8's ![]() http://www.aufalcon.com.au/3x-puursui7 |
#14 | |||
Audi S3
no utes came with the 220. only the 200kw motor. except the pursuits 250's, which got the stroker. answer you question as to why there are no wings? ford told you a porky ![]()
#15 | ||
MoPar man 11
Ok thats a fair opinion that FORD are telling me stories and Mechanics must be backyarders. Can anyone tell me if the 200 KW came out with a signature engine in the utes with a 70mm throttle body (the car is factory original Tickford) Also the code of the engine on the ID plate has a Z code. Now the wreckers get a updated book every year of what each make of car came out with, The AU11 ute says the engine code on the ID plate should have an X code, Do all XR8 AU1 11 or 111 utes have the Z code on ID plate ?? I have seen an XR8 AU111 SEDAN with a Z coded ID plate and that in the wreckers manual means its a 220 KW engine... I was also advised before I recieved my car by the dealer principle at Adrien Brien Ford that my ute was getting a 220KW engine, Does or can anyone advise me of a FORD expert in Adelaide that would have the time to have a look for himself, Coz I need this settled as i get contradicting information... Thanks for your help and time anyway.
#16 | ||
Hey mate, I just bought an AUII 8/01 XR8 Ute. (With signature on rocker cover) - All 200kw/220kw engines had the signature built engines.
It has engine code Z. It does not have the Tickford Wings on the Throttle body, (are you sure your measuring it right? measure the side that the air comes in) It also has Yella Terra 1.7's on it, that the Series 3 got on them. So either Ford fitted them at factory, or during a warranty claim of some sort, or the previous owner did.
Heritage Green EL Ghia Black AUII XR8 Ute |
#17 | ||
Ok, just called 13FORD, 220kw WAS an option during the later months of the AUII Ute.
(according to the person i spoke to...) Sadly, mine is not one of them! ![]() P.S Sorry to take over your thread NEILLY
#18 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
#19 | ||
Boost is here!!
If the T/B does not have Tickford Wings it is not a 70mm. You need to measure behind the butterfly to get the correct measurement. No good measuring at the front as it has a bellmouth.
If it doesnt have the Tickford T/B it would only be a 200kw engine, as the bigger T/B is obviously a contributor into the extra 20kw.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
#20 | |||
MoPar man 11
#21 | ||
Boost is here!!
Got pics of it?
Dont worry bout butting in this thread is a year old.
#22 | |||
RAM 1500
#23 | ||
Young !@#$ Head
I love these forums... Even after the owner states the dealer principal at ford had a 220 kw engine put in the ute obviously some people on here must no more about every single falcon ever produced by ford then Ford themselves know. There is every chance your ute DOES have a 220 kw engine in it as IF the dealer principal at FORD ordered the ute and was willing to wait the time for delivery FORD could have put it the ute. But hey maybe FORD has no idea what cars they built and what they put in them.
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
#24 | ||
Boost is here!!
Yeah it also suprises me how much information is on these forums and people still dont do the research.
#25 | |||
RAM 1500
#26 | ||
Engine code Z indicates a 5.0 V8 SEFI. There is only one code to indicate a V8 in the AUs, and it is Z. This would be the same for AU1 through to AU3 and does not indicate 185, 200, 220 or 250 power; it simply indicates V8. It is the same for EB through to FG also, with the only models to get a different option code of J or T being an EB, ED and EL V8 (I'm guessing these were fitted to the GTs in the case of the J designation, and the Sprint in the case of the T).
Engine Code of X is for the 4.0 I6 (HP), and has never been used by Ford to indicate a V8. The answers have been here the whole time; why do people not use the resources of this site properly? http://www.fordforums.com.au/vbporta...warticle&id=17
#27 | ||
Hey give me a break, I havent owned the ute long and i was 100% certain it was 200kw just as I had read on these forums.
However after finding the Y/T rollers on it, i became more interested so started reading up, then found this thread and thought, 'Why not, i might call ford and find out'. I pretty much read every single thread on here regarding this topic and wasnt posting to make trouble, I found it an interesting topic. :S
#28 | ||
Boost is here!!
Sorry Stevo, my last post wasnt directed at you.
#29 | |||
RAM 1500
#30 | ||
MoPar man 11
6FPAAAJGCM1D21696 is my VIN and FORD say its a 220 KW.... Thanks all for your time and efforts people
Rgds Gazza |
