Hey guys,
Does anyone have the tutorial that was on AUFalcon.com previously regarding how to remove the bumper? JC made two references to it but it isn't there.. I assume it was lost when the site got upgraded. Those things on the plastic guard liner, are they like clips or screws? Thanks again |
ok, you have to remove your head lights, as there is a screw or bolt holding the bumper on under them, you then pull the plastic guards off in the wheel arch, just get a screw driver , slip it under the plastic and yank the plastic screws off, and if you have the plastic stone guard under the car as well you have to remove that also as there is plastic screws the same in the inner guards holding it on also
hopes this helps cheers
They are push in clips - usually called xmas trees. Prise them out with screwdriver or cut them off with side-cutters. They are cheap to replace. Places like Repco have them if you don't want to pay Ford prices.
AU Falcon Man
im pretty sure you dont have to remove the headlight... i thought you have to remove the front bar to get the headlights our... (because the bar overlaps the bottom of the headlights...) as far as i remember all you have to do is get to the 2 nuts at either side wheel arch (that you have to move the wheel arch guard to get to, move not completely remove)
Cheers Cam
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
![]() Join Date: Nov 2007
^^ exactly. thats how i changed mine.
wrong wrong wrong frd906... have some lunch...
![]() T3man, for further refrance, they are called scrivits... alltho there are 2 of the x-mas tree clips... AU bar is easy... 2x 13mm bolts both sides behind the splash shield... a rot of umm 7 or 8mm bolts under the bar... and bobs ya uncle... its a 5 min job not even... Don't bother trying to take lights out with bar on = fail and putting parts under stress... |
wtf, you go have some lunch mate,
you have the stone gaurd underneath which is connect to the bottom of the bar, also the wheel arch plastic, they have to come out and 2 bolts on either side in the wheel arch, simple mate
obvisouly mate you done have the plastic stone gaurd underneath skotty
Yeah you don't have to remove the headlights to remove the bar. But otherwise frd906's instructions are pretty much spot on.
My front bar is drooping excessively though, and luckily I can take the headlights out easily anyway. That was the main reason why I wanted to take the bumper off. |
my instructions were right then, if you mentioned that you were taking the head lights out i was right,
becuase i have done the same thing as well
#11 | |||
#12 | ||
First Ford Owner
a average AU owner would no longer have a stone guard as the bastards keep breaking!
(if you dont have one..) only need to undo the wheel arch guards and undo the bolts as im under my car to often the stone guard just gets in the way so i've kept it off!!
If you dont like the heat, then get out of the bloody fire |
Critical Thinker
I will eventually need to remove my front bar soon for some minor mods. I might get you to give me a hand Skotty when the time comes.
