I have an instrument cluster from a T3 TE50 for sale in the parts for sale section on here. Someone is asking will it fit into a std 5.0L Plug & Play OR would mods be required ?
Anyone know the answer to this ?
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
AU3 5.0L Fairmont Wagon
![]() Join Date: Mar 2011
It's plug and play. The only real difference is if they have a high series cluster that shows each individual door open the TS cluster will only show the pic of all doors open
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar Ford Performance Club of ACT [SIGPIC][/SIGPIC]
Thx mate
Lacking Imagination
I Believe if it is going into a Low Series that some pins will need to be reallocated to work with the cluster.
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
it is by no means plus and play but can be done, you need to relocate 4 wires to a plug that isn't there so you will need to acquire the plug to make it work ( or use an alternative that fits the pins, computer motherboard header plugs will fit. series one is not compatible with later series due to the wiring of the speed alert through the steering wheel controls, try mixing series one and later clusters and you will have major dramas ( been there done that)
[SIGPIC][/SIGPIC]
#6 | |||
Lacking Imagination
Taken from Ford Mods
I had my TS 50 cluster plugged in my fairmont and did not have to make any modifications and have all lights illuminated and working properly. Still running in the car without problems
Lacking Imagination
TS50 is based on a Fairmont, So it would of just worked Ray
![]() TS50 = High Series Fairmont = High Series
Which is what I said at the start ... Re TS50 and high series ...
Lacking Imagination
Yep I know.
I am just confirming what you said. But OP never specified what type of car it was going on so i thought i'd just make it clear,
Yep true
