03-04-2006, 06:22 PM | #1 | ||
Hi Guys
About 3 days ago my car devloped a miss out of the blue and very quickly. When I drove to work in the morning is wasn't there and when i went home in the afternoon it was there. So i did a bit of research on the form to find out if anyone else had a similar problem. I found that most people just changed the leads and plugs. I had a look at the leads and plugs and from what i can tell they look like the orignal ones that the car came with. So i changed both. After i finished i took the car for a drive around the block and all seemed good. Then this morning i drove to work only to find that the miss was back, not as bad but still there. Before i replaced the the leads and plugs and now the miss is only noticeable when i accelate, when i get up to speed it goes away and it's not noticalbe at idle Any ideas Thanks Alpineau |
03-04-2006, 11:20 PM | #2 | ||
they call me Tibbo
if plugs and leads has made a difference, all that is left and the most likely culprite the coil pack is weak and might need replacing
03-04-2006, 11:35 PM | #3 | |||
Walking with God
GK |
03-04-2006, 11:37 PM | #4 | ||
they call me Tibbo
I'm sorry I can't help you to test it GK, If I have a miss and plugs and leads didn't fix it, I just put a coil pack on...
03-04-2006, 11:42 PM | #5 | |||
Thanks for the reply racecraft. I will post the problem after it's get's back for the workshop tomorrow Cheers Alpineau |
03-04-2006, 11:48 PM | #6 | |||
Walking with God
GK |
04-04-2006, 09:47 PM | #7 | |||
05-04-2006, 12:04 PM | #8 | ||
horsepower
GK DOES IT HAPPEN MORE WHEN UR ACCELERATING FROM STANDING START ??
because i believe i might have the same problem , because mine only happens when i am pushing when it gets top end it goes okay and i dont feel the miss ???? and how much was the repairs in total .. ?? |
05-04-2006, 09:45 PM | #9 | ||
Fantastic Plastic
might sound silly , but did you clean/replace your air filter while doing the spark plugs and leads ? is the gap correct on the spark plugs / a few might of needed adjusting a tadd ?? .. I dunno if it would maybe goto the extent of making the car miss beat unless it was totally blocked/the air filter ( where only high revs would cause enough vacume to get the air through the rubbish in the filter suficientlyr ) ? .. just a maybe ..
05-04-2006, 11:45 PM | #10 | |||
Walking with God
GK |
05-04-2006, 11:47 PM | #11 | |||
Walking with God
GK |
