Old 17-08-2006, 06:09 PM   #1
Ruger
Bseries Moderator
Ruger's Avatar
Default Engine options on KF laser
Hi,
im looking to build a cheap track only small car
KF laser can fall into this category (also looking at 20v ae82, b16 civic).
i would be starting with a cheap straight body and engine/gearbox would be replaced as will suspension breaks wheels and tyres
im aiming about 200hp n/a or more i was wondering what motors could be slotted into the laser and how tuneable are they (aftermarket parts availability).
b6 engine springs to mind but i know sfa about them
could someone please educate me or point me into the direction of a source of info on them.
cheers
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 12:57 PM   #2
VippiN
What a performer!
VippiN's Avatar
So you only want N/A? Ignore the B6 engines, the BP engines (1.8L DOHC EFI 92Kw @ fly) are solid and have huge potential if you have huge pockets. They also slot almost straight in as they come stock in the KF TX3's.
You'll also want the G Series gearbox from the KF TX3's, you won't have any problems being FWD.
If you want to go forced (who wouldn't..)
BPT's comes stock in the KF/KH TX3 4WD's and the engines are plentiful (117kW fly)
BPD's come from the Mazda Familia GTR's (142kW fly) and they are the same as the BPT's apart from stronger internals/management/AFR .. There are KF TX3's running almost 300kW with these beasts.
You will get a lot more information then I can provide at www.fordlaser.com In particular if you are interested in N/A only PM 'Razor' as he has a rally car BP powered and is the N/A guru around those parts.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 04:10 PM   #3
Ruger
Bseries Moderator
Ruger's Avatar
hmmm it seems i will probably go with a corolla as i can get a ae101 front cut for >2500 that comes with a 20v blacktop (137kw n/a) ecu loom 5spd lsd box big front brakes and better suspension
throw that in a 1000 dollar corolla and i should be able to have some fun.
ill check out that site and well see how i go
Old 18-08-2006, 07:30 PM   #4
VippiN
What a performer!
VippiN's Avatar
137kw N/A? Crazy! Good luck with it
