Old 07-10-2006, 06:10 PM   #1
auvct
auvct's Avatar
Default fairlane boot hinges
Hello people.
I'm wondering if anyone has had troulble with the passenger side boot hinge lever on their fairlane?
Is there some sort of bush assembly?
I know you have to remove the inside moulding to get to the bolt to tightened it up.
It seems like it works its way loose and then my boot is out of wack and wont close.
Is this a common problem?
www.theretrofitsource.com
auvct is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2006, 11:53 PM   #2
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
No troubles with mine and it's opened and slammed shut about 10 times a day.
AU-MUSTD is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 12:13 AM   #3
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Put some locktight on the nuts next time you tighten them , or use another nut behind the original and tighten the second nut hard into the original tightened nut / cheers.
:eclipsee_
Old 08-10-2006, 09:11 AM   #4
auvct
auvct's Avatar
thanks guys..
