SCALDED CAT
Hi guy and gals....just wondering if anyone here has changed the fitting that screws in to the top of the power steering pump ( 5ltr ).....I have got the fitting from ford....and the manual I have doesn't really say how to do it....any info would be great cheers Rory!
"THE CAT IS BACK" |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Had to replace mine allso as far as I am aware the pipe & fitting has to be replace as one unit cause the fitting locks on the pipe and carn"t be removed once fitted ( it is the last peice to connect up once you have the pipe in place ) the hole unit cost $140 odd from Ford... my old pipe is still in the shed waiting for a mate from Enzed to look and see if he can make a cheaper alternative ..
P.S you need real long arms to get the pipe back ware it came from or a helper. its a pig of a thing . also don"t clip the fitting on the pipe till it"s back in it original place .. Cheers Whoosha
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
SCALDED CAT
Thanks for the info mate....got a price from Ford this morning.....$216...god Ford are a rip off...!!!
"THE CAT IS BACK" |
![]() Join Date: Dec 2004
Mate try the old ATP or motospec at 80 webster rd stafford .They supply auto trans and power steer parts .Will be lot less $$than ford 07 38561500 i think is the number
a.k.a PAULY
By using a grinder or die grinder ever so carfully grind the old fitting off without hitting the main power steering line ,it takes a while but beats paying $200 odd dollars for a new one
2002 silhouette pursuit 250 manual,brembos, 3.73,s 2002 blue print pursuit 250 in restoration 1995 WMW250(CR250) dirtbike fully road registered 1947 ford thames tipper V8 21 stud flat head 1939 ford beer barrel truck V8 24 stud flat head HZJ diesel ute HJ47 diesel ute |
SCALDED CAT
Thanks for all the info....I will try the die grinder....and if I'm to clumsey I will give the guys at the auto trans place a buzz!!!
"THE CAT IS BACK" |
