AU II XR8
Hi, iv been looking at buying an AU XR8 for some time now and have found an AU XR8 REBAL with 65,000ks on the clock, now just playing the waiting game, cause the dealers are trying to rip me off!
Just wondering if you guys can give me some ideas of what to look for when going over the car, example, any common engine problems the windsor might have. thanks.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER Last edited by needaXYGT; 16-05-2009 at 06:44 PM. |
rebels are sweet! They kinda have a 2 tone kit. 220kw handbuit engine, special mags, leather, etc. Best bet when buying a car get a nrma check about $150 save ya heaps in the long run, or even your usual mechanic. But at 65k it's barely broken in ;).
If not start with service books, should have had a recall for the steering colum- wasnt anything major. Look for leaks at the engine, gearbox, and diff etc. Take it for a spin see that it steers all straight, do some u turns etc listen and feel for wheel bearings, control arm sounds squeeks rattles etc, take it out on some 100km roads and listen for diff whines. Depends if it's auto or manual, auto feel for nice shifts- no lag or waiting for it to change gear etc. Manual you want nice smooth shifts that arnt to clunky but au xr8 manuals kinda do anyways lol, Go around and push down on each corner of the vehicle and you want them just to bounce back and stop. not alot of bounce back. The windsor engine is pretty good a little asthmatic lol but some on here have done 300k+ and still going strong.Rebels have the 1.72 YT's and 70mm T/B and svo alloy heads, so there a good starting ground for mods,Also regular maintance and tlc will see yrs out of it ;) Other than that? sounds good got any pics? and ask em if there gonna chuck in a ps2+ grand tourismo ![]() Last edited by dreadly; 16-05-2009 at 07:05 PM. |
AU II XR8
Do you remember the problem with the steering colum?
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
Umm ring ford with the vin and they'll tell you if it needed doing or has been done. Cant remember i had to get mine done or i think we didnt bother and just had it listed as done? lol it'll come up on the screen when you get a service at ford.
Wasnt anything major hey think they add a bolt or something? should be sweet as. How much are they asking? |
not here much anymore
It wasnt the column it was actually the steering rack and from memory it was only 6 cyl models that were affected. my old AU3 never had any recalls done and never needed any.
RAM 1500
Was all au 2 models. No mention of series 3.
AU II XR8
Thanks for the info so far. The asking price is 20k, but iv managed to get it down to 16k, still not low enough for my liking though. Last time they had an Au XR8, they did the exact same thing, price was to high, so it sat there for 3 years and rotted away with only 46k on the clock, but they reakon they can get more for it. If they can, then good luck to them, ill just have to find another one.
$16k is good Turn up with $15K it's an awesome buy hey ;) considering 65k ago it would have been $45k+ you saved $30k off purchase price and it's had 3 services
AU II XR8
Is this the engine they were fitted with?
Windsor 5-litre V8, OHV, electronic multi-point fuel injection, 9.0:1 compression, SVO Y303 alloy heads with larger valves and ports, roller rockers, 70mm throttle body, EEC V engine management system, special cam shaft, electronic ignition, extractors, 220kw @ 5250rpm, 435Nm @ 4000rpm
no. alloy heads were only on te 50 series one.exactly same car as series 3 xr8
#11 | |||
i believe that is correct ![]() |
#12 | ||
Windsor 5-litre V8, OHV, electronic multi-point fuel injection, 9.0:1 compression, SVO Y303 alloy heads with larger valves and ports, roller rockers, 70mm throttle body, EEC V engine management system, special cam shaft, electronic ignition, extractors, 220kw @ 5250rpm, 435Nm @ 4000rpm __________________ Yep thats right, cedrics wrong ![]() |
Cat be Still !!!
Doesn't matter much,,there's an obvious weight saving with the alloys but at the end of the day, alloy or iron its still 220 killer wasps.
#14 | ||
Made the 300 :0)
NO they had cast heads from what i can find ,Also 9:4:1 Also a cam from Crow Part No 621338 which was mild because the heads flowed good with the valve size and alittle porting by yella terra.
New Owner of a fiesta ST |
#15 | ||
formerly "3x-puursui7"
im led to believe some were lucky enough to get alloy heads as they were left over from the t-series or i might be thinking of something else?
all hail the mighty V8's ![]() http://www.aufalcon.com.au/3x-puursui7 |
#16 | ||
Giddy up.
They did NOT have alloy head's, period.
They were a stand alone XR8 series III special , the same engine as every other series III XR8 220. |
#17 | |||
Afterburner + skids =
![]() Join Date: Dec 2004
No alloy heads, they had cast GT40P's.
#18 | ||
Guess i was wrong then sorry about that. Or could it be a case of the au xr8 ute some got 1.72's some got 1.6 RR's. Maybe someone out there has one with alloys?
But still they only made 250 of em, There a nice car and 65k for $15-16K is a good buy ![]() Stick some pics up or a link to it? |
#19 | |||
Giddy up.
I meant they were the same engine as the series III 220kw. |
#20 | ||
AU II XR8
ok thanks guys. the car isnt adverstised online and i dont have any pictures of it. I beleive there was only 125 of them made as well?
#21 | ||
Well if thats true..... go get it lol ;)
#22 | |||
Walking with God
They got it for much less than 14K so I reckon they just might take it. All the very best with it. GK
#23 | ||
No factory alloy headed XR8's exist as far as I know, if they do exist it's more than likely something the previous owner did.
The Rebels are a good bit of kit but a Series III with just as many options ticked is pretty much the same vehicle so don't be conned into paying extra coin just because it is a Rebel - unless you get the playstation that went with the car when they were sold new.
RAM 1500
#24 | |||
#25 | ||
Hey new guy... Get &^*ed! :the_finge
Have a look at every post you've done..... bahaha dont smart being cheeky after 2mths! |
#26 | |||
#27 | ||
So's pretty much everyone of your posts.....38 in -8weeks lol
![]() Thats enough outta me lol im sick of getting banned ![]() Last edited by dreadly; 19-05-2009 at 07:38 PM. |
#28 | ||
#29 | ||
Hahahahah Thats awesome peuty! Indeed lol
