T3 TE50 Blueprint
I have done a search on this because I have seen some 12pt ARP bolts on some windsor build ups on here before, but do you think I can find the info now that I actually need it? Of course not.
![]() So if any of you guys and gals out there can recommend what size header bolts I should use- even a part number would be helpful- as I don't want to use the 7/16 head size bolts I currently have, looks like they have been done up with an open ender as even my little 1/4 drive thin wall sockets won't fit over without fouling on the primary pipes. Thanks heaps -Craig |
not here much anymore
Craig,
ARP-100-1202 - should be about $30 or so. Let me know if you cant locate them and I will order you some.
RAM 1500
#3 | |||
T3 TE50 Blueprint
-Craig |
or you could take an old sample to a bolt merchant and get some cap screws and washers if needed.
