Old 01-08-2013, 11:19 PM   #1
zx10
zx10's Avatar
Default AU XR8 clutch noise, is it normal?
Hey guys,
My clutch makes a squeaking noise when it is not engaged. As soon as I put any pressure on the pedal it goes away, also if you lift the pedal it goes away.
Someone told me that it was the throw-out bearing touching the fingers of the clutch? Bad design was the reason and no cure was given. It is really annoying.
Any ideas?
AU3 XR8 sedan - Manual, Leather, Momo wheel/gear knob
zx10 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2013, 09:12 AM   #2
madmelon
Default Re: AU XR8 clutch noise, is it normal?
Mine does the same thing exactly. It's annoying and it's getting worse...
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2013, 11:49 AM   #3
james22
With da Warlords
james22's Avatar
Yeah Thrust bearing is starting to wear out, It will only get worse
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 02-08-2013, 01:01 PM   #4
zx10
zx10's Avatar
Cool. So long as it can be fixed cause it ****** me right off.
Old 02-08-2013, 02:13 PM   #5
BOTTLEDUP
Fixed by changing the clutch & spigot bearing. So gearbox has to come out.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2013, 02:25 PM   #6
madmelon
I figure I'll do it when I do clutch- 129,000km and counting!
Old 02-08-2013, 02:39 PM   #7
Julza
871 Productions Filmmaker
Julza's Avatar
Mine does exactly the same, due for a clutch anyway. Good to know it's a common issue!
cheers,
Julza
Edge SY MKII Territory TS AWD
Blueprint AUIII Falcon XR8 Ute
Lightning Strike BA MKII Falcon XR6T
http://www.youtube.com/871productions
Julza is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2013, 03:08 PM   #8
superroo
You can't stop the signal
superroo's Avatar
Not a bad idea to do engine rear main seal and gearbox input shaft seal at the same time either
Old 02-08-2013, 04:01 PM   #9
zx10
zx10's Avatar
Lol mines just hit 110ks. Clutch still feels strong so ill put up with it for a while longer.
Old 02-08-2013, 09:44 PM   #10
Gaz
Got Ghia?
Gaz's Avatar
Yep, mine squeeks first thing in the morning, disappears after a while.
I'm in no rush to replace it!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2013, 04:45 PM   #11
needaXYGT
AU II XR8
needaXYGT's Avatar
Mine does it also. The ute makes a squealing noise in the mornings with the clutch peddle in and a fair bit of squeaking with it out, but once it's warmed up its not too bad. The clutch is still strong though, so not too worried about it.
My XR8 sedan also made noises for 5 years, but never failed.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2013, 09:46 PM   #12
cedric
my ute does too. put in a new one only lasted about 3 months so then changed clutch and new throw out, it lasted about 30 000k and is doing it again now. never had these problems with my sedan so maybe there is some sort of common issue
23 t-bucket 302w c4
1969 xw falcon 302w t5
1977 lwb f100 351 c6
cedric is offline   Reply With Quote Multi-Quote with this Post
