27-11-2019, 05:26 PM | #1 | ||
2016 MD Mondeo Trend. I spend a fair bit of time just sitting in the car. The radio time-out is at about 10 minutes. Is there a way to extend the time out? I've gone through the manual and had a dig around the internet but can't find a way.
27-11-2019, 06:19 PM | #2 | ||
with ign off? if you turn accessories on should be more like an hour i think
27-11-2019, 07:24 PM | #3 | ||
I might be a bit thick - where and how do you do only accessories? Push the radio on/off button gives you about 10 minutes. Pushing the start button with your foot OFF the brake switches everything on including running lights, fan, etc.
28-11-2019, 08:10 AM | #4 | ||
If your vehicle battery is a couple of years old you might find that after an hour of the radio being on; you wont have enough power left to start the engine!
28-11-2019, 08:52 PM | #5 | ||
You're not thick at all pawd.
Two options as far as I know, without actually starting the car. Hit start button once without brake = ignition on and all features of the car are activated, and start button flashes. Hit start button twice without brake = turns on Sync features, including radio and bluetooth, and start button light goes out. Agree this times out after about ten minutes. |
29-11-2019, 02:27 AM | #6 | ||
On the MB you can turn the stereo on and it switches off after an hour. Doesn't that work on the MD?
29-11-2019, 10:28 AM | #7 | ||
Thanks all - looks like the MD is only going to allow 10 minutes no what you do.
29-11-2019, 08:39 PM | #8 | ||
30-11-2019, 11:19 AM | #9 | ||
Yes it does restart the timer. But as sure as "God made little apples", you're gonna forget (been there, done that).
30-11-2019, 07:45 PM | #10 | ||
Have you tried Ford to find out if time can be reprogrammed via scantool in central vehicle configuration Something may have been altered at some stage - battery saver or similar
01-12-2019, 10:23 PM | #11 | ||
Yes, you can surely update the settings within the appropriate module to change the time-out value - I am very confident you could adjust that - the very hard bit is knowing what memory location you have to change the value of.
But, I found this for a Mustang - and they often share similar modules: Stereo Extended Play APIM 7D0-01-01 : xx?x xxxx xxxx Change ? To: A-Off, 2-20 minutes, 3-30 minutes, 4-40 minutes, 5-50 minutes, 6-60 minutes I don't have the Forscan software anymore to look at this module in my own vehicle to see what it's set to... if you were really passionate about getting this done; then you might want to phone around a few specialist dealers to see who would be prepared to make this tweak -I guess it would be more likely possible from the performance tuners. Good luck! |
