Old 18-11-2008, 07:06 PM   #151
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
Originally Posted by The Mighty Red
WOW , great time Croc!....Is this the quickest Clevo on here?.....Is there a Cleveland hall of fame were you post your best time like the in the AU Falcon forum
Most likely the quickest here, even quicker than some bigger cubed super sized specials.
WOOOOOOOOOO
FPV GT 03 /341 RWKW OF N/A POWER.
XB GT 73 /OLD FORD MUSCLE
ALL AUSSIE MUSCLE
HEMI POWER is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 07:26 PM   #152
xdclevo
The Fun Mobile
xdclevo's Avatar
Thats about what you're old 351 XD ran wasnt it?
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 07:37 PM   #153
crochunter
440cube Dart
crochunter's Avatar
XD was on nitrous. This is natural asspirated.
Facebook
crochunter is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 08:23 PM   #154
xagsjoe
Patience is a virtue
xagsjoe's Avatar
Hats off Croc ole son. What you going to be happy with et wise with the current setup?
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 08:38 PM   #155
crochunter
440cube Dart
crochunter's Avatar
I will be really happy when it runs a 10.2. I know that this engine can run real quick but not with the compression it has at the moment. Compression is very low. The cam thats in it at the moment is way too big for the compression i am running. But when it runs a 10.2 i am going to put nitrous on it. There is still some sorting out to do with rear end yet and gearing. Going to get some new leaf springs when i find out who makes them. Also get some caltracs. Also put some 6 cyclinder springs in it. As it still has the v8 springs in it at the moment. Also more fiddling with the carby and exhaust off i am sure it will run the 10.2 i am after. I will get car weighed this friday and see what it weighs.
Facebook
Old 18-11-2008, 08:39 PM   #156
protd
TUFF FORDS
protd's Avatar
good to see it moving along well..
i'm not so sure it's the quickest clevo on here though..
protd is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 10:46 PM   #157
debacle-racing
debacle-racing's Avatar
there is a 357 cube 2v in a 3200lb falcon ute that went 10.15@131 at sydney a few weeks back. the owner is a top bloke too!!!
well done croc, tough rego'd combo.
Originally Posted by TruBlu351
..........and thanks to Justin from Debacle Racing for helping me hook up and break parts
debacle-racing is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 11:18 PM   #158
debacle-racing
Originally Posted by crochunter
R/T- 407
60ft- 1.515
330- 4.292
660- 6.658
mph- 103.59
1000- 8.713
ET- 10.465
MPH- 128.79
It still needs more gearing as now the stall is locked up and not slipping its not crossing the line with enough revs. Plus it should be 60ft in the 1.4s. Going to get some caltracs and try. Also still sorting out the Pro Systems Carby. Every time we go to the track it gets a bit quicker. It just seems like the Pro Systems carbies need to go bigger in the jets all the time. Should also make a difference when i take the exhaust off.
once you sort out your sixtys, your et will tumble.
if you can get it to 1.40 ish your et will / should be around 10.2x.
i have some suspension ideas for you if your interested, just pm me you mob number.
cheers, justin.
edit. nice reaction time too!!
Old 18-11-2008, 11:34 PM   #159
robbie
XT 351/4V
any more info about this?
robbie is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 11:51 PM   #160
debacle-racing
what would you like to know.
it runs a std crank, 302 rods and acl hypers, 246 solid, cast 2v's, ultraflow eradicator manifold, 750hp, c4 with a brake 9" 4.33 gears, 29.5 x 10.5 mt's
Old 18-11-2008, 11:55 PM   #161
robbie
XT 351/4V
what a killer 2V combo... gobsmacked mate.
Old 18-11-2008, 11:58 PM   #162
debacle-racing
and a wiff of gas............ forgot to mention that.
Old 19-11-2008, 09:53 PM   #163
protd
TUFF FORDS
protd's Avatar
hey croc would you mind scanning the slip for us to have a look at
Old 20-11-2008, 08:27 AM   #164
protd
TUFF FORDS
protd's Avatar
double post sorry
Old 20-11-2008, 08:28 AM   #165
protd
TUFF FORDS
protd's Avatar
obviously your not willing to share the cards, could you tell us how many times you run the car and what were the other times??
did it run the 10.40 at night in the cooler air or during the day, what other times did the car run on the day?..
looks like you have it heading in the right direction anyway, good luck with it
Old 20-11-2008, 06:27 PM   #166
crochunter
440cube Dart
crochunter's Avatar
The car ran a 10.6 off the transbrake and a 10.4 with transbrake at night. On the day time the track was all over the place as the car was wheel spinning bad as there was no traction. It was running 10.7s and 10.9. During the day it was showing 13.5 on the air and fuel ratio guage which is still a bit lean. Went up 3 sizes in the jets during the day but it was still running lean. Carby still needs more tuning. Will be racing it again soon at Tassie track to get the carby jetting sorted out. Going to put some new leaf springs and caltracs in it first. There were heaps of cars running 5mph and half a second of there times.
Facebook
Old 20-11-2008, 07:43 PM   #167
xdclevo
The Fun Mobile
xdclevo's Avatar
I know what you mean mate. I only had one shot at it with no cage, but it was on a street meet with no track prep, and the V8 front springs didnt help the cause. Small pipes/carby didn't help either
408 cube Cleveland
10.7 @ 125 mph
2V powahhhhh
Old 20-11-2008, 07:55 PM   #168
protd
TUFF FORDS
protd's Avatar
well it seems to be heading in the right direction keep it up.. good luck..
and dion put a cage in that sucker
Old 20-11-2008, 08:19 PM   #169
xdclevo
The Fun Mobile
xdclevo's Avatar
Yeah, most probably will. cage,cam,pipes will be on the list.
I'm sick of the street car anyway
Wouldnt mind shovelling it in a torana 4 door
408 cube Cleveland
10.7 @ 125 mph
2V powahhhhh
Old 24-11-2008, 09:24 PM   #170
crochunter
440cube Dart
crochunter's Avatar
Might try a mid size hornet scoop. As i have been told i could gain up to 2 tenths in changing to a forward mounting scoop. Some people have not had any sucess in cowl scoops. I think from memory the dandy car went quicker when they went back to a forward mounting scoop.
Facebook
Old 03-05-2010, 06:52 PM   #171
crochunter
440cube Dart
crochunter's Avatar
look out. Some good times about to come.
Facebook
Old 31-08-2010, 04:35 PM   #172
crochunter
440cube Dart
crochunter's Avatar
This is the dyno sheet from where i had it put on the dyno 2 weeks ago in Melbourne. Wanted to see how much hp my motor really made at a proper acceleration rate. Car is going to be run over the quarter mile on 18th September. Hoping to run a 10.2.
Facebook
Old 01-09-2010, 07:00 AM   #173
landau460
BA MK2 GT
landau460's Avatar
http://www.danasoft.com/sig/bluecortina.jpg
Clicked on your link and got 'your ip is ****** iknow where you live !@#$%what is with that ?
A lot of people think i know f#@$ nothing but in actual fact i know f#@$ all! I'm collecting Landau pics
Fords I've owned
80 escort panelvan, 73 Landau, 73 xa fairmont, 74 Landau, 75 Landau, 75xb falcon, 67 falcon, 80 xd falcon, 94 ed falcon, 05 mk2 GT
landau460 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2010, 01:21 PM   #174
crochunter
440cube Dart
crochunter's Avatar
Will put time slip on here when it runs.
Facebook
Old 12-12-2010, 09:55 AM   #175
crochunter
440cube Dart
crochunter's Avatar
Changing from 4.3 gears to 4.56 gears how much revs will i pick up. As car is only crossing line at 7000rpm.
Facebook
Old 12-12-2010, 12:29 PM   #176
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
G'Day Croc,
Your new converter has a 4.35% slip which is nice and toight.
Based on your current 130mph trap speed, to get that same speed using 4.56's with your 4.35% slip and 28" slicks, you'd be doing 7400rpm.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2010, 01:36 PM   #177
crochunter
440cube Dart
crochunter's Avatar
G'Day Croc,
Yeah 7400 is about where i want to be. I have a set of 4.86 but i reckon it would be revving a bit too much across the line.
Facebook
Old 12-12-2010, 10:15 PM   #178
TruBlu351
TruBlu351's Avatar
I agree. You'd be pulling some hot 1/8 mile times! but to get 130mph with your setup & 4.86's, you're looking at 7800-7900rpm! Would sound good, but seeing as your peak power is at 7000, you'll probably go backwards??
