30-12-2006, 07:33 PM | #1 | ||
Hi, I have a XH XR6 ute. I recently just replaced my head gasket, I got the head decked and everything, but I feel that it doesn't have as much power as it used to. I used a Durapro head gasket kit but I keep hearing about the AU head gasket, I think its AU. Why use that head gasket, and could it be that the durapro head gasket made my compression lower or something?
31-12-2006, 01:37 AM | #2 | ||
Aspiring mr efxr
i think AU h/g is thinner there for ups compresion.
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
31-12-2006, 10:37 AM | #3 | ||
Is upping the compression a good thing?
31-12-2006, 10:47 AM | #4 | ||
Apprentice Fridgey
Location: In a lil place called Gladstone aka. Glad2bstoned
Have a look on the ACL website for the CopperHead Gasket. 1mm thick and it raises the compression a fair bit, only thing is there about $200, but it's well worth the money
96 EF Falcon Futura, Powered by Microtech, 2222549 Crow Cam, Metal Gasket, Port and Polish, Oversized Forged Valves, EF Fairmont Dash, K&N Highflow Filter, Pacemaker Competition Extractors, 2 1/2 Mandrel Bent Exhaust, High Flow Cat, Converter Shop 3500 stall, Shift Kit, 4.11 Diff Ratio, Mini Spool Best ET 14.654 @ 88.270Mph at Benaraby Raceway, Gladstone Queensland |
31-12-2006, 03:44 PM | #5 | ||
Aspiring mr efxr
yeah more compression is wot u want.
01-01-2007, 11:19 AM | #6 | ||
so replacing the durapro head gasket with the multi-layer steel one will up my compression, the reason I'm asking is becuase I don't know the thinkness of the two. Will it make much of a difference because it not I won't bother then.
01-01-2007, 01:13 PM | #7 | ||
Apprentice Fridgey
go to this site http://www.aclperformance.com.au/For...perGaskets.htm and it is exactly the gasket you need
10-01-2007, 08:49 PM | #8 | ||
Ive got a duropro one in now, so if I change it with a multi-layered steel one will I see a difference? I don't want to waste my time doing it.
10-01-2007, 08:54 PM | #9 | |||
10-01-2007, 10:08 PM | #10 | ||
Isn't it also the AU's have different pisions with little dish, thus making more compression!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
10-01-2007, 10:54 PM | #11 | ||
If you've already changed the gasket then there is no point doing it again, for the small increase in compression/hp you will get.
