Old 14-12-2005, 11:22 PM   #1
Mavvyholo
Default HELP is it my fuel pump?
Hey all, I really need to know if it's my fuel pump before I spend any money moving the car, (95 EF futura) it just decided to die out of the blue, still has all electrics so it can't be that, and also fuel, what I did notice is when I turn the ignition to ON before START, I can't hear the electric whine of what I believe was teh fuel pump? coz yeah nothing now, advice??
Old 14-12-2005, 11:23 PM   #2
John_LS1
sounds like fuel pump, or possibly fuel pump relay
Old 14-12-2005, 11:24 PM   #3
EBFalcs
does the car crank over
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 12:13 AM   #4
Mavvyholo
Yep cranks just fine, just no engine action at all, not even a sputter.
Old 15-12-2005, 12:28 AM   #5
snypereb
[EBGLT]
snypereb's Avatar
A little wierd mate but it sounds like a fuel pump!
[EBGLT]
Old 15-12-2005, 01:29 AM   #6
-jjM-
-jjM-'s Avatar
yea defornetly the pump, same problem before, dose the dial still move on the cluster when u go to start?
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 09:59 AM   #7
Mavvyholo
Yep fuel gauge is still working, another question, is the fuel pump internal? as that's a way bigger job :
Old 15-12-2005, 10:54 AM   #8
MustangNicko
MustangNicko's Avatar
The fuel pump is in the tank, its not a hard job... Check the fuel pump relay as well
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 03:58 PM   #9
mcflux
mcflux's Avatar
Yes, check the relay first. My relay was "sticking" so it would randomly have issues when starting. Once it took me 40 minutes to start the damn car.
My mechanic was honest with me & said it turned out to be my relay, after I'd said I wanted a new fuel pump fitted. Saved me $$$!
Relay: $20 2nd hand
Pump: $250ish
-Dave-
Old 15-12-2005, 04:25 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
So there is a cheap option and an expensive one!
[EBGLT]
Old 15-12-2005, 06:05 PM   #11
-jjM-
-jjM-'s Avatar
could just pinch the plump out of a wreck, i pinched mine out the ED and worked fine, as well it did like ...300+kms
Old 15-12-2005, 10:16 PM   #12
NZ
NZ's Avatar
Take off the cover to the fuel pump in the boot and give the pump a few taps with something solid while someone else repeatedly turns the key from off to on. Usually a failing pump will start running occasionally.
Old 16-12-2005, 11:28 AM   #13
EA1191
Have any of you guys heard of logic? And why do not some experts check these posts.
Check for spark at the plugs. Check for power to the pump. Check for petrol, maybe disconnect he fuel line and when the ignition is switched on, AND THERE IS POWER TO THE PUMP, some fuel is pumped into a container. The power relay can be manually closed to run the pump. Make sure the fuel line is secure when reconnecting, maybe cut off the end.
Better to check fuel pressure.
Could be something completely different like the idle control. Or the computer.
EA1191 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 01:32 PM   #14
NZ
NZ's Avatar
Mate the 'experts' probably have better things to do. And yes logic suggests that when the guy says he doesnt hear the fuel pump running when the key is turned to on that he should be looking at that first and not checking for spark. None of us can claim to be experts here, some of us think we are but most are just learning. So perhaps leave the 'oh ffs' attitude off here ;)
Old 16-12-2005, 01:38 PM   #15
turbo00007
Boost
turbo00007's Avatar
Check for spark at plugs
If no spark check the crank angle sensor
I had same problem couple years back on a NF Fairlaine
The bad news is it turned out to be the ECU in the passenger
kick panel
The car just stopped as i was pulling away from a set of lights
Never went again till i got ECU repaired
XR6T
turbo00007 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 01:41 PM   #16
turbo00007
Boost
turbo00007's Avatar
Fuel pump will only run for a couple of seconds anyway till car starts
For his sake i hope it is the fuel pump
XR6T
Old 16-12-2005, 04:07 PM   #17
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
hit the fuel pump cover hard in the boot
like giv it a goof bashin a few hits
and it will get it to start! =)
only last for about 10 days but before it dies completely
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 06:00 PM   #18
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
I would check the relay as it is a
common prob with fords, once the
relay goes u have no hope to
start it.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD.
TO MANY YEARS IN THE MAKING : :1syellow1
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 09:56 PM   #19
Mavvyholo
Hey all an update for your reference! ;p It was the fuel pump relay, and also a 30amp fuse wire of some sort that needed replacing, all fixed, and btw, I'm getting 17" csa avenger wheels on wednesday! (same as brute utes) wooot
