23-08-2009, 07:13 PM | #1 | ||
does the i6 require back pressure from the exhuast or not, cheers matt
23-08-2009, 07:27 PM | #2 | ||
Yes it does however the size of the exhaust matters my own opinions are 2 and ahalf inch on mildly modded and stockish cars and 3inch on majorly worked n/a and ofcourse turbo or supercharged I6's
23-08-2009, 07:44 PM | #3 | ||
Smile
The less backpressure you have the faster your car will go and more power it will make.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
23-08-2009, 07:48 PM | #4 | ||
'04 BA XT
I agree with stav, I have a 3" on mine and it goes faster than the smaller systems I ran.
1979 F350 Tow Truck 80 series Turbo Diesel Cruiser |
23-08-2009, 07:50 PM | #5 | ||
No engine needs backpressure.
23-08-2009, 07:51 PM | #6 | ||
you have to have some back pressure and not have none at all
23-08-2009, 07:51 PM | #7 | ||
Just slidin'
3 inch is good, 2.5 inch is good. Its up to you.
MD Mondeo - For the family
23-08-2009, 07:52 PM | #8 | ||
Smile
You reduce pumping lossess by openning the exhaust up regardless of the countless exhaust shop experts advice. The car gains power because the piston has less restriction to push against.
23-08-2009, 07:53 PM | #9 | ||
Just slidin'
Why do you want the car to have backpressure?
That means there is a restriction. We aim to have no restriction. Thats why cars at the drags, either drop the exhaust before the cat, dump it out from the collectors behind the front gaurd, or if really crazy have some Zoomies
23-08-2009, 07:57 PM | #10 | ||||
Is that a question or a statement? If its a statement, a-bit badly written, then why bother asking the question?
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
23-08-2009, 08:00 PM | #11 | ||
i said dosent the engine have to have some back pressure, alright, then no back pressure at all meaning no cat or muffler
23-08-2009, 08:03 PM | #12 | ||
but the muffler and the cat is the restriction, if you had a high flow cat and muffler you still have back pressure but very little, at all
23-08-2009, 08:06 PM | #13 | ||
Just slidin'
We cant run no exhausts on the street, hence why we have "Hi-flow" cats and mufflers.
23-08-2009, 08:07 PM | #14 | |||
Smile
23-08-2009, 08:09 PM | #15 | ||
but in saying that, you will always have pressure, unless you are a idiot and just have straight pipe all the way through, like the bommbadores
23-08-2009, 08:16 PM | #16 | |||
Smile
23-08-2009, 08:17 PM | #17 | ||
i have to replace my cat as all of you no i had that accident , so im replacing the cat tonight or tommoro, the going to spend 88 dollars to get the car on a machine to make sure she is running spot on and will let you no,
23-08-2009, 08:26 PM | #18 | ||
You're always going to get some backpressure - In an I6, you have the exhaust gasses from 6 cylinders all bombing down their individual pipes to a collection point somewhere in the system (unless you run 6 exhaust pipes). When these gasses meet, most of it go down the exhaust, but some goes back up creating "back" pressure. Restriction of the system is not the same thing, and opening up the pipes past the collector point will help reduce back pressure, but it will not be eliminated.
Having answered your own questions about 4 posts after you posed it, I'm not even sure what your intention is with this thread.
23-08-2009, 08:31 PM | #19 | ||
i was just asking on peoples thoughts
23-08-2009, 08:31 PM | #20 | ||
and as to see if it was true or not
23-08-2009, 08:34 PM | #21 | ||
Workshop & Performance
I was reading up on this subject the other day and found this article....
The below is quoted from: http://www.miata.net/garage/KnowYourCar/S4_Back.html The general idea being excess backpressure is a no-no, but no backpressure can equal compromised exhaust gas velocitys....not a Ford but totally relevant. <SNIP> Urban Myth Number 42: "MX-5s need backpressure" It is easy to see how this misunderstanding arises. Lets’ say that Max puts a 3-inch system on his normally aspirated car. He soon realises that he has lost power right through the power band. The connection is made in his throbbing brain…. put on 3" pipe = loss of backpressure = loss of power. Max erroneously concludes that you need backpressure to retain performance. He has ignored the need for exhaust gas velocity to get that scavenge effect. If Max had chosen a 2 1/4" pipe he would have achieved better performance in the mid- to high-RPM power band. You need the combination of the least positive (close to zero) backpressure possible with the highest gas velocity achievable to create performance. The diameter of the pipe (and smoothness of internal finish and bends) will strongly influence if your exhaust change is going to create performance or lose power. As a general rule, a normally aspirated MX-5 will get better high RPM performance with a 2 1/4" exhaust system (2 1/2" or above is just too wide to retain exhaust gas velocity for street driving). The general consensus is that a 2 1/4" system is for mid to high RPM petrol heads. Your mechanic should be able to advise you what exhaust system will best suit you driving style and needs. Forced induction (turbo or supercharged) MX-5s perform better with the high volume pipes (2 1/2" to 3"), but that’s another story. The choice of a 4 into 2 into1 or a 4 into 1 header to exhaust set is yet </SNIP>
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1 A stereo that happens to have a XR5 wrapped around it |
23-08-2009, 09:10 PM | #22 | |||
Smile
23-08-2009, 09:24 PM | #23 | |||
In your first post it was quite clear what you asked "does an I6 engine need back pressure". The simple answer is categorically NO. This is not my thoughts on the subject - it is a stated fact. It has been proven so many times that it amazes me how aften it still comes up - an urban myth that won't go away. It is simple physics that a high school kid can teach you. The best exhaust is NONE - straight out from the exhaust valve/port to the atmosphere - this allows for the engine to be tuned for it's potential maximum power. As you add varying lengths of piping and restrictors like cats and mufflers then the tune of the engine has to be compensated and power is lost - like I said, it is simple physics and is undisputed fact. |
23-08-2009, 09:33 PM | #24 | ||
Hate to say I told you so. That apology can be made via email, msn or personal message.
23-08-2009, 09:43 PM | #25 | ||
"He has ignored the need for exhaust gas velocity to get that scavenge effect"
If the scavenge effect isnt relevant, we might as well all bin our headers I've thrown a PM to Thunder in the hope he can help out with some real knowledge here...
23-08-2009, 09:57 PM | #26 | ||
Maximum exhaust gas velocity is achieved when the gas can leave the combustion chamber totally unimpeded. Again, it is simple physics and there is no room for argument.
Exhaust "scavenging" only becomes relevant once you add piping to the exhaust passage; like on motor cars. And it is true that the exhaust system has to be properly designed and the engine appropriately tuned to get the maximum benefit. But the most power an engine can possibly produce will always be with the lowest possible backpressure. On a street driven vehicle that maximum power may not be at appropriate revs for maximum driveability so quite often an exhaust system will be used that promotes better driving response at the cost of the loss of some potential power. |
23-08-2009, 10:17 PM | #27 | ||
Im prepared to sound stupid as Im just guessing here and forget most of what I was taught over the years....
So exhaust scavenging is used to help reduce the effects of having a limited escape path for the gases by effectively REDUCING the backpressure that would be normal in a system of 'x' size (well for each cylinder that is being 'scavenged'? So scavenging does NOT increase the velocity of escaping gases above that that would be experienced by venting to atmosphere? Im making no suggestions above, just asking questions!
23-08-2009, 10:18 PM | #28 | ||
basically who gives a about that stuff no the engine doesnt need back pressure but if u want to drive it on the road it needs an exhaust so will have back pressure if you like it or not the end jesus
23-08-2009, 10:36 PM | #29 | |||
Pepe Le Pew is on the right track |
23-08-2009, 10:47 PM | #30 | |||
paule11> I don't doubt that - BUT the simple fact remains that the engine was tuned with an exhaust system in place - you remove it and the tune will be shot - you re-tune it for NO exhaust and it will go harder that it ever did before. Race engines run the absolute minimum of exhaust piping - think about it - would they do this if there was a benefit to be had by running an exhaust pipe twice as long? |
