11-11-2020, 10:46 PM | #1 | ||
I have a 1998 AU1 Fairmont with the 4.0l 6 cylinder. I am the second owner and I know for a fact that the car has been very well serviced all of its life and has spent most of its 300,000 km life on highway cycle. Since owning it I have driven it like an old fart and drive rurally at no faster than 80 kmph and 100 when I am on the highway. I run the car on 98RON fuel, but cannot seem to get any better economy than 11.3 L/100km. This seems to be absurdly high for a car that has been treated like a baby all of its life. Even with the ECON mode selected, the car does not show an improvement in economy. The car starts and runs like a Swiss watch except for in cold weather where the car will start ok, but then stall even though a second start will fix the problem. Any clues why I am getting such rotten fuel economy?
11-11-2020, 11:54 PM | #2 | ||
#neuteredlyfe
Fuel regulator.
You can replace them easy enough but you can sometimes get away with giving it a clean. |
12-11-2020, 12:14 AM | #3 | ||
12-11-2020, 01:24 AM | #4 | ||
#neuteredlyfe
Yep, no dramas.
The reg can get clogged up for any number of reasons such as dirty fuel or even just over a period of time. If the reg gets clogged up it can cause the car to run rich. Sometimes when they run rich there are no other telltale signs other than high fuel consumption. |
12-11-2020, 01:32 PM | #5 | |||
15-11-2020, 06:27 PM | #6 | ||
#neuteredlyfe
I wasn't referring to whether it is running lean or rich. You said that you are getting poor fuel economy and it is hard to start of a morning.
That would suggest to me that it is the fuel regulator. I had a very similar problem to yours (and still do to an extent) but once I cleaned the reg it improved out of sight. I suggested the fuel regulator as it is the cheapest thing to look at first. Your two problems could either be caused by the same problem or completely separate problems. It very well may not be the fuel regulator and could be a number of things, such as;
The above is not an exhaustive list. You could always run a scan over it to check to see if it could be something else. Sometimes scans though do not pick up the actual problem though. Failing that, spend the money and buy an O2 sensor and see if that works. |
15-11-2020, 08:14 PM | #7 | |||
