Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
25-10-2008, 11:13 AM | #91 | |||
Race Brakes Sydney
We are making a 330mm kit as we speak and it along with the twin piston kit we do retains the e series offset which is why they have been selling well.The uprights can be purchased outright from between $100 to $150 a pair depending what we pay from the wreckers and they can be done in ABS or non ABS .The rotors supplied are with EF EL ABS rings fitted but if an earlier model is needed you have to remove the sensor and fit the early ones on as they have a different amount of teeth.The early model abs rings are about $20 or so each i think.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
25-10-2008, 06:00 PM | #92 | |||
Member
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car. Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw. |
26-10-2008, 11:19 PM | #93 | ||
Member
Also, any idea what size wheel to get over it? 17" or 18"?
343cm = approximately 13.5" so probably get most 17" wheels over them I would think.
27-10-2008, 10:59 AM | #94 | |||
Race Brakes Sydney
The 343mm kit would take about the same to make and orders are about 3 weeks wait at the moment but it won't be long before orders aren't done until after Christmas.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au Last edited by FLOORED; 27-10-2008 at 11:12 AM. |
19-11-2008, 09:04 PM | #95 | ||
G'day,
what upgrades do you have for an XE?, we use it as a track car at Winton, it currently has standard size DBA slotted rotors, PBR Performace pads, standard callipers and lines, and DOT 5 brake fluid. Standard brakes and pads on the rear. We would really like to go bigger, but stay within the 15" rims, what do you recomend? |
20-11-2008, 12:27 PM | #96 | |||
Race Brakes Sydney
MATTHEW PEARCE
29-12-2008, 05:43 PM | #97 | |||
Member
30-12-2008, 09:47 PM | #98 | |||
Closing on Wednesday the 24/12/08 and re opening on Monday 12/01/09 |
02-01-2009, 10:21 AM | #99 | ||
Member
Dang, 10 days to wait! :-(
09-01-2009, 11:11 PM | #100 | |||
Race Brakes Sydney
MATTHEW PEARCE
10-01-2009, 02:18 AM | #101 | ||
roughneck
Mate, I believe the BF MKII XR8's and XR6T's came with an upgraded brake package.
Do you know what the upgrade over the BF MKII XR6 was and would you recommend that upgrade or an equivalent that you do? I'd like to beef up my brakes but I'm not neccessarily looking at a full Brembo kit if you follow me. Slotted front rotors, braided lines and maybe DOT 5 fluid with some good pads? Thanks
Ego XR6 BF MK 2 NA, 6 spd Auto. Eng mods - Plazmaman air pipe and airbox w/pod filter & xr8 upp snkl, undrdrv, xtrctrs+2.5 hiflo cat & zorst, K & N fltr, BPT Custm tune. 175rwkw. Hndlng mods-1" lwrd Kings sprngs, Whiteline sway bars. Bling - lwr grill, 19x8 Dark Ardent rims w/ 245 Maxxis, custm tail lites, XR scff plts, XR mats, Shift-i, pod gages, Fairmon chrm boot trim, chrm mirrors, boot de-bdge, red au xr6 side bdges, alloy fuse & comp covers. To do: Hndlng mods - brake upgrade |
10-01-2009, 05:04 PM | #102 | |||
XR6 front rotors are 298mm and rears are 316 solid disc XR6T & XR8 Front rotor 322 and rears 328 ventilated disc I have these on my BA and the difference in braking was quite amazing. I also put braided lines on mine. Unless you were going to be doing track days there would no need for anything bigger than this setup. Give Matt a call on Monday, he is back from holidays then and he will be able to sort you out. |
10-01-2009, 10:39 PM | #103 | ||
Is the link below the 322mm that come in the XRT6 & XR8???
http://cgi.ebay.com.au/FALCON-AU-BA-...1%7C240%3A1318 |
11-01-2009, 05:20 PM | #104 | |||
roughneck
13-01-2009, 10:47 AM | #105 | |||
Member
13-01-2009, 01:29 PM | #106 | |||
Race Brakes Sydney
MATTHEW PEARCE
13-01-2009, 02:40 PM | #107 | |||
Member
13-01-2009, 04:53 PM | #108 | |||
Race Brakes Sydney
MATTHEW PEARCE
13-01-2009, 08:00 PM | #109 | ||
Stay Classy ™
Just wanted to jump in and thank Matt for the Brembo 4 + 4 setup he did for my AU Ghia just before Christmas, had all the gear in within a couple of days and ready to install within a week .. the setup has been fantastic and gave it a good run during a recent Ford cruise ... could outbrake all the T3 TS50's on Tickford premiums without a trouble
14-01-2009, 01:57 PM | #110 | |||
Race Brakes Sydney
MATTHEW PEARCE
15-01-2009, 06:30 PM | #111 | ||
Member
any update?
16-01-2009, 01:28 PM | #112 | |||
Race Brakes Sydney
Front 343mm 2 piece slotted disc with 4 piston AP caliper to suit E series @ $4400
MATTHEW PEARCE
16-01-2009, 08:58 PM | #113 | |||
Member
17-01-2009, 10:22 AM | #114 | |||
Race Brakes Sydney
MATTHEW PEARCE
21-03-2009, 09:04 AM | #115 | ||
Member
Kit arrived Thursday. It is now installed. Pictures:
Installed them last night and replaced my drivers side strut rod to K-frame Nolathane bush that had sheered itself, so didn't finish till 23:00 by which time the old man was asleep so I couldn't bleed them. On my way to do that now though, and then give them a test and get a wheel alignment.
21-03-2009, 11:02 AM | #116 | ||
Boost is here!!
Damn they look good!!
If only i could have stretched the $$ that far to get that kit. Maybe one day ;)
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
21-03-2009, 04:54 PM | #117 | ||
very sexy brakes dude, let us know how they go
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc |
