Old 22-04-2009, 10:14 AM   #1
PTMK11
Default MK11 Cortina
Hey guys, I have a 1970 MK11 Cortina and I am wanting to put a 302c or w in it and even a 351 if it would fit without playing with shocky towers. I know the Radiator needs to be moved forward. But just wondering if anyone has done this conversion and could give me any ideas on what needs to be done. or any other suggestions people might want to throw out.
PTMK11 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2009, 01:52 PM   #2
DougM
There were a few mark 11's with big blocks in them years ago doing the rounds in the magazines......Full streeters........Check with the RTA as I don't think you can put a V8 into an early cortina/escort anymore. It depends on each state though......
DougM is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2009, 07:43 PM   #3
75Cortina
75Cortina's Avatar
Hi, PTMK11
First off, welcome to the forums.
As for the V8 in a mk2, i have seen it done before with all types of 8's like Clevo's and Windsor’s, Obviously a 302 Windsor is going to be easier to squeeze in.
The ones that I’ve seen done have had the firewall cut and moved to allow for some more room at the front of the motor, i would guess that there is some work involved in fitting a 8 in.
However correct me if I’m wrong but i think that the MK2 Cortina’s have the same engine bay as a MK2 Escort and a Capri, if this is the case all you should need are some mounts and a sump and pick up to make it fit, it will be tight though =)
Also as Doug Said if you want the car to be street registered check with the RTA in your state, last time i checked the RTA in BNSW was stopping V8's well anything over 4.0LTR displacement into Escorts and Capri's and i think the MK2 is in the same weight range, having said that a Toyota 4.0 V8 in a MK2 would be nice!!!
Hope this Helps,
Current Project: Rebuilding my Corty!
220kw Au3 XR8 Engine, full Custom Zorst, EMS Computer, Underdrive pulleys and MSD coil Parks.
TKO Tremec 5 Speed
Full Floater 9in 31 Spine with locker
Its almost there!!!!
75Cortina is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2009, 09:33 AM   #4
PTMK11
Thanks 75 Cortina,
Will check the RTA im in QLD and pretty we have worst laws against engine conversions and that so that could suck!
So you reackon maybe a 1UZ-FE? out of the soarer's arent they?
Im not too worried on doing a bit of work to fit it in but i want it street registered so will have to check the RTA.
Thanks anyways mate
Old 23-04-2009, 07:07 PM   #5
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
there is info on mk1s and mk2s v8 conversions
http://www.cortina-mk1classifieds.com/forum/index.php
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2009, 07:53 PM   #6
Roy Rogers
Escorts and Capris don't have the same engine bays, infact there's more space in a Mk2 Cortina engine bay than a Falcon it's just the guards are a lot wider on a Falcon which makes them seem bigger.
President
Small Ford Car Club of NSW
www.smallfordcarclubofnsw.com.au
Roy Rogers is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2009, 04:05 AM   #7
75Cortina
75Cortina's Avatar
1UZ-FE that was teh engine i was taking about, Yep there out of the soarer's, the bottom end in them is strong as!
'Escorts and Capris don't have the same engine bays' fair enough, its just the way that there finished looks very similar,
Anyway good luck with the conversion,
TKO Tremec 5 Speed
Old 25-04-2009, 11:45 AM   #8
cortina-mk1
Heavy right foot
a straight 6 is going to be tuff to get registered as it will need firewall mods
a v6 is prob gunna be a good option if want to go the 6 cylinder way
there is a new thread started with a v8 in a mk2 HERE
if you havent already seen it
Old 25-04-2009, 06:48 PM   #9
P100 Ute
P100 Ute's Avatar
1uzfe is a 4.0L V8.
you might of been thinking of the 1jzgte which is the 6cyl.
in saying that.. theyre a 700mm cube almost.. so depending on the width of the engine bay is whether or not a 1uzfe will fit.
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2009, 07:16 AM   #10
75Cortina
75Cortina's Avatar
Should be able to get it in, i've seen big blocks in MK2's!
I've also seen a V6 out of a Capri in one that seemed to fit pretty easily.
Let us know what direction your going to take, might have to start a build thread?
TKO Tremec 5 Speed
Old 26-04-2009, 11:10 AM   #11
cortina-mk1
Heavy right foot
Originally Posted by P100 Ute
1uzfe is a 4.0L V8.
yea no probs
should have been more clearer was referring to a 250 - 6 ford
