Low and Loud
Im thinking of doing the serp conversion to my car since
* A/C needs to be reinstalled anywho * 70amp Mitzi doesnt cut it, 110amp is needed for all the crap going into the car * Power Steeringpump is crappy. Now most stuff I need can be sourced from work I assume, but I need to know exactly what I need... Alternator Harmonic Balancer Idler Pully? A/C Compressor Power Steering pump Belt (Obviously) EF Timing cover Also I remember there being some issue with having to get a XH1 Tensioner? Thanks
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Last warning
talk to Dave, he did it :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#3 | |||
Low and Loud
Last warning
so who better to talk to then someone who did it first hand? :P
If you put your mind to it you can accomplish anything......
#6 | |||
Low and Loud
#7 | |||
Low and Loud
Ill check with you next time before I start a thread :P
#8 | |||
Last warning
gee sorry mick, suggesting someone to talk to is a big no no now.
remind me not to reply to ur threads then
88 miles per hour!!!
EA2BA did this conversion too, but from memory there was some issue where his car wouldn't start or something. :P |
#11 | |||
Low and Loud
If someone who has a list of what parts I will need it would be great
#12 | ||
Talk to dellboy, he did it and then his car wouldn't start :P
Yes, I know I haven't done it yet, but you need - Power steering pump + bracket Alternator + bracket A/C comp Harmonic balancer - ef or el will fit, but if you get the el one there shouldn't be the extra gear for the crank sensor Timing case is optional, you can always just whack a little notch in for the timing. Belt (obviously) If you want to keep your current manifold (ie, MPFI) you will need an XH tensioner. Dayco sell them. If you switch to BBM, you'll need the EL a/c brackets and you can use an EL tensioner. Hey, if you do it before I do, I'll come give you a hand, so we can see what breaks on your car first! :P |
Low and Loud
Thanks steven, Just what I wanted to know.
I will be staying MPFI as BBM has no benifits in my car.
#14 | |||
#15 | ||
they call me Tibbo
talk to OED666 also ,,he did it when he went to the AU engine.. There was some issue with the ED log manifold and the A/C compressor iirc
#16 | |||
windsor user
as they had the 4litre with ED manifold and serpentine belt.... also, i do recall SWOOPA having some isses with AU into Eseries around the ac compressor... i cant recall what he ended up doing, i think he modified a bracket..?? someone correct me |
#17 | |||
Low and Loud
#18 | |||
#19 | |||
windsor user
#20 | ||
Former E-Series Member
If you're using the XH tensioner (pre BBM), you will be using the XH belt as well. I bought an AU belt for mine and had to sell it and then buy an XH.
#21 | ||
I think the best option would be to buy a complete EF or EL then swap everything over.
Hope this helps.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#22 | ||
Regulator
XH belt is about $30
You can use an EA or EB compressor if your happy to change the pulley ;) Or you can just use a EF type one... Also save some $$ and change the power steering pump pulley (very easy) instead of swapping pumps because you'll have problems with the hoses. Everything is easy bolt on e.t.c, don't forget all brackets you'll need too, I did it on my EA and it was a fantastic mod.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
#23 | ||
Performance moderator
![]() Join Date: Feb 2005
We have done it ... An AU engine into EDXR6...Lol....
#24 | ||
Undergraduate EB Operator
what has to be done to the AC compressor, wrong pully? not in line with everything else? im considering doing this myself in the next month when i put thermos in
Simon ----------------------- 04 BA Xr6 ... now with carpark dints ![]() ----------------------- |
#25 | ||
Regulator
You can either get a cheap dodgy EF compressor (as I did) and not hook up the lines, or change the pulley on your EA one which is not really hard just needs to be compressed out. The aircon lines are different IIRC, but you still use your EA plate, not sure what others done here but I went the dodgy way and had no air con
