Old 05-10-2005, 01:49 AM   #1
QUIKXR
Question Problem removing ECU
i have an au2xr8.
I cant remove the bracket that holds the ecu so therefore cant remove ecu.
it is not a screw that is holding the bracket its is somtething else. can someone please tell me how to remove this to get to the ecu???
any help is much appreciated! thank you
QUIKXR is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 05:28 AM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
It is a large rivet mate, you have to drill the sucker out
Old 05-10-2005, 12:38 PM   #3
JC
JC's Avatar
If it's a torx headed screw, you can use a 5mm socket to remove it. If it's a rivet, then drill as per Racecraft's advice.
Ford Performance Club ACT
Old 05-10-2005, 12:50 PM   #4
Sourbastard
Contributing Member
Sourbastard's Avatar
And if that dont work, go the Gas Axe.
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 05-10-2005, 04:43 PM   #5
QUIKXR
How do i do this?
Old 07-10-2005, 12:57 AM   #6
EvilChief
Boost Addict
use a drill and press the trigger
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 07-10-2005, 04:09 AM   #7
QUIKXR
sorri i dont know as much as you wise guy!!!
is there a certain drill bit to use becayse i wouldnt have a clue how to drill that out
Old 07-10-2005, 04:35 AM   #8
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Where are you from? If you are in a bit of a bind and pushed for time it might be quicker to give someone a call. I'll PM you with my number as an option if you get really stuck. You only have to use approx. 4mm-5mm drill. The head of the rivet is much larger than the rest of it. If you have a centre punch, would be best to use it as the head of the rivet is convex and the its difficult to keep drill centred(very important). Once this is out you can open the bracket up like a hinge. From memory I don't think you can fully remove it. There certainly a bit more to the story but I'm already late to start my shift. Sorry. I hope you get the help u need or give me a ring.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 10:04 AM   #9
AUGhiaV8
Find a drill bit a couple of cm larger than the centre hole/core of the rivet and drill straight through the middle... hopefully it should just pop off or fall appart then (once the core is removed). If it drills through and still doesn't come out try the next drill bit size up and so opn until it does.
