23-12-2012, 11:04 AM | #1 | ||
Just wondering if anyone can tell me if the AU has a wide or narrow band O2 sensor as I am looking at getting a Air/Fuel gauge put in.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
23-12-2012, 11:38 AM | #2 | ||
Performance moderator
Std tmk use narrow band.. Need another bang welded on to take wide band..
23-12-2012, 04:15 PM | #3 | ||
not here much anymore
Standard is narrow band, if youre putting an AFR gauge in you would need a wideband.
Why do you want that gauge? Pretty well useless unless you're tuning it.
RAM 1500
23-12-2012, 04:48 PM | #4 | ||
Well not sure what other gauge to put in Aust. I want oil temp but don't know what else to put.
Already have oil pressure and volts on the cluster.
23-12-2012, 04:59 PM | #5 | ||
The oil pressure gauge in the cluster is only an 'idiot light' - goes off if its pretty well too late.
RAM 1500
23-12-2012, 04:59 PM | #6 | ||
Just another mock-up..
Oil temp and trans temp maybe..?
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
23-12-2012, 05:02 PM | #7 | ||
Actually, yours is manual isn't it..? Scrap trans temp then..
23-12-2012, 05:06 PM | #8 | ||
yeah its manual....so don't know what else to put and what brand and series gauge
23-12-2012, 05:13 PM | #9 | ||
Just fit a boost gauge..
It will give you an incentive to supercharge or turbocharge..!!!
23-12-2012, 10:09 PM | #10 | ||
Cruising...
Oil and engine temp? Two very very important things youd want to keep an eye on with proper accurate reading gauges not the cluster ones which can be more of a rough guide than an correct indication.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
24-12-2012, 10:12 AM | #11 | ||
5.6L x 2 pilot
A wideband is a pretty expensive option for a gauge. Some widebands such as the Innovate LC-1s that I run do not need an additional bung welded in. One of their analogue outputs can be used to simulate a narrowband signal, so it can be placed in the existing o2 bung.
Agree with a proper oil pressure gauge. Haven't you noticed that the in dash one never moves from the same spot - even at startup? Good luck. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
24-12-2012, 12:25 PM | #12 | ||
I think I am sold on getting a oil temp and pressure gauge. Need to now find a gauge to suit my series 3 cluster with white back lit and black face. If all else fails I will go the cobalt series from Autometer
