30-12-2010, 02:45 PM | #1 | ||
I have done some research on this site and others about upgrading the S1 brakes.
Do you really need to change over the control arms and swaybar? just to gain a different bolt pattern or can you just get better calipers that will bolt straight on? what is the best option? |
30-12-2010, 03:03 PM | #2 | ||
Boost Addict
nup needs changing ... as the tutorials / other threads say everything needs changing
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
30-12-2010, 03:40 PM | #3 | ||
Just slidin'
You can do the big upgrades from companies who supply them. Think they are around the $1400 for the fronts, and the same for the rears.
MD Mondeo - For the family
31-12-2010, 09:55 AM | #4 | ||
www.TUFFCARPARTS.com
There was also a premium brake option for series 1s, they do pop up for sale very occasionally. While this would be a straight fit up they are fairly rare.
31-12-2010, 12:27 PM | #5 | ||
Boost Addict
the S1 have no bolton on points, instead a full floating bracked casted into the upright, that along will inhibit bigger rotors and calipers. What does this S1 premium package include?
31-12-2010, 09:54 PM | #6 | ||
cheers fellas looks like i will go for the full S2 upgrade as it will give me many more otpions and a better swaybar setup i believe. the tutorials on here are the go will print one off and give it a crack! i will source parts first though.
04-01-2011, 09:46 AM | #7 | ||
woop woop woop woop
hi, i was wondering if it is possible to go to a series 1 XR6/8 calipers, discs and pads as an upgrade option for series 1 rather than upgrading the front suspension to series 2/3? thanks
04-01-2011, 12:23 PM | #8 | |||
There are 3 choices for series 1 owners looking to upgrade: 1. Fit Tickford premium brakes (328mm rotors, twin spot callipers). rare, and pricey 2. Fit aftermarket brakes from Cebco, or race brakes. Not as rare, but still pricey. 3. Fit AU2/3 or BA suspension components and brakes (callipers & discs). Plenty around and costs should be in the $500 range.
04-01-2011, 01:19 PM | #9 | ||
Walking with God
Lock in option 3 thanks Eddie!
GK
04-01-2011, 01:51 PM | #10 | ||
Just slidin'
In all honesty, a good set of pads and rotors will do the job admirably unless you are planning 20 laps of QR.
04-01-2011, 03:18 PM | #11 | ||
Still on the topic of series 1 brakes, mine feel very 'fady' as in slowing down for some lights, if i put a consistent pressure on the pedal and dont keep pushing it down, the car barely slows down and i do really need to keep pushing the pedal in to start slowing down at a reasonable rate, and i am talking about normal traffic braking here nothing extreme. Is this just the series 1 brakes becasue i have been in other AU's namely series 2/3 that require stuff all effort to slow down. or do i have some other problem
04-01-2011, 03:26 PM | #12 | ||
Lacking Imagination
ive been looking for an upgrade as well, my AU Fairlane needs to really have the pedal pushed. we found out that there is almost no pressure coming out of the Master Cylinder for the rears
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
04-01-2011, 04:01 PM | #13 | |||
04-01-2011, 05:16 PM | #14 | ||
Just slidin'
Id say you have other issues other than it being a S1 problem. I done the brake upgrade from Standard to DBA and Bendix pads, and from S1 - S2/3, and also S2/3 to BA.
I honestly could tell didly squat between them all EXCEPT brake fade going down the far side of Mount Glorious. I never had a problem with any upgrades and brake fade, just standard S1 gear. I had the brakes glow red, and then Warp undriveably when they cooled.
04-01-2011, 05:16 PM | #15 | |||
Flairs - Truckers Delight
04-01-2011, 05:37 PM | #16 | ||
Walking with God
My S1 wagon had woeful brakes. I upgraded them to dba slotted rotors and bendix pads on the front. Not much better.
I then went a S2 upgrade, (no upgrade to the master cylinder) with rda slotted rotors and QFM pads. Much, much better. I prefer the bite and fee on my S2 SR sedan (which has the same rotor and pad combo), but I put that down to the S2 master cylinder and a bit less weight. If I got another S1, I'd do the upgrade again for sure. GK
04-01-2011, 06:38 PM | #17 | ||
Got a fairlane sereis 1 V8 had pulsation problems and struggled to slow down changed to slotted with bendix ultima, were ok for a little while then same problem, done a full front conversion with BF XR8 callipers RDA slotted disks and original ford pads never had a problem again, conversion was a pain in the but as i had to drop the extractors to put the sway bar brackets bolts on the inner rails, if you've got a 6 much easier. Full conversion parts only cost me about $1100 with new bushes.
04-01-2011, 09:56 PM | #18 | ||
adrian
Good slotted rotors and a decent set of pads plus a high quality dot 5.1 fluid and your S1 brakes will be much better. Remember these are the same as was on all E series falcons, and I know I am not the only one that thrashed them on the track.
I do remember i found a crowd on Melbourne that sold conversion kits, ie new uprights , brackets, calipers, discs etc, essentially ELGT spec. You had to send them your old upright with the ears in exchange.
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
04-01-2011, 11:24 PM | #19 | ||
woop woop woop woop
thanks for the help, guess i'll go with the series 2/3 conversion then
the XR8 calipers i saw were definitely twin pot front calipers, i think they were stamped PBR so i don't know if that is standard XR8 or not but they came off a series 1 XR8 which is why i was asking |
05-01-2011, 01:48 PM | #20 | |||
05-01-2011, 07:46 PM | #21 | |||
After a few heavy stops they'd work quite well but if they were allowed to cool down again while driving on say a ten km country stretch without any use they were absolutely attrocious again. I don't want to have to warm my brakes up so I got rid of the "premium" pads that were in it and put in some standard ones and the problem was gone, gone, gone. Now it has lovely brakes when cold. As for the series ones, I say there's nothing at all wrong with series one brakes. My series one LTD's brakes work pretty much just as well as the series two fairlane's now that the pad material selection on both is in tune with my driving style. Properly set up series one brakes will pull a car up very quickly but pad and disc selection needs to match the manner in which the car is operated or shall we say "driving style". The series two "upgrade" is a thicker disc to deal with heat and a slightly larger pad surface (which then required two smaller pistons to keep it flat on the disc) but it's not really a huge upgrade. Pad and disc selection will still be the biggest determinant of brake feel and performance. This may sound silly but I've tried aftermarket ebay discs on both my AU's and dumped them for genuine Ford ones because I reckon the ford ones felt better under the foot and they bedded to the new pads much faster than my aftermarket ones too. |
05-01-2011, 08:52 PM | #22 | ||
cheers for the information, its good that many people have tried different things and are willing to share can save other people lots of trouble! i did only go cheapo pads recently and unmachined stock disks becasue i had the upgrade to S2 in mind so that might be my biggest problem atm.
05-01-2011, 09:34 PM | #23 | ||
adrian
it can be a compromise, stop when they cold and fall apart when hot or stop when they are hot but not when cold. Ferrodo DS2000 seem like a good compromise from all the pads i have tried over the years.
05-01-2011, 09:58 PM | #24 | |||
EDIT - thanks to the encyclopedia of AU's (JC): 1. Fit Tickford premium brakes (328mm rotors, twin spot callipers). rare, and pricey |
05-01-2011, 10:39 PM | #25 | |||
Next upgraded Mk1 Leopard
06-01-2011, 01:54 AM | #26 | |||
Someone towing or operating in stop start traffic isn't going to need to make his first cold stop from 100kmh so he an get away with a bit less cold performance until his brakes warm up from the normal stop start which happens relatively quickly due to those harder conditions so he needs to choose a higher temp pad than I do. My XJS club car needed a real high temp pad for the club's Conrod supersprints cos that first stop at the Chase would heat the supposedly high performance jag pad up so much that they wouldn't make Murray's corner without fading half way in let alone allow another hard stop from a full bore entry into Hell corner. On the other hand I used really soft pads for the esses hillclimbs because it only had to brake hard once so cold performance became most important again. So yeah, it's all a compromise but one needs to select the right gear for the conditions and having tried heaps of different pads over the years in various cars I see huge differences between them in operation, specially now that asbestos has gone. Disc material seems to vary nowadays too. |
09-01-2011, 01:42 AM | #27 | ||
I just finished my AU1 to BA brake upgrade today and it doesn't look half bad. Would like to have done this in a garage or a workshop with use of a hoist but beggars can't be choosers.
09-01-2011, 09:11 AM | #28 | |||
Boost Addict
09-01-2011, 12:26 PM | #29 | ||
i was lucky and picked up a complete bf front brake assembly of ebay for $56 , refubished the calipers new pistons seals the lot , got the calipers thermal coated , and the brackets zinc chromate plated as per factory all for $250 odd bucks on top of the purchase price , cheaper than what would have cost me if i had purchased from a wrecker, they were wanting around $450 for the complete setup, calipers, discs, hubs & uprights
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
09-01-2011, 08:15 PM | #30 | |||
