My Xr8 220kw that i brought new in 2001 has had 2 water pumps and needs another one now.
Is this a common problem. What would cause them to leak on the seal every time. It has done 77,000 km's, Rego is (XR 8220) has 171rwkws, and been no problem other than the water pump issue. |
Back on the road
leaking at which seal?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
335 kw of goodness
Haven't heard of it being a common problem. There is the odd one that has had a new pump fitted for one reason or another...
CAUTION! STILL Contain's opinion's & fact's that may offend !!! ![]() 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
#4 | |||
Front rubber shaft seal.
Back on the road
Hmm....that is curious. Not something I had heard of happening to anyone else either (not to say it doesn't happen though)
What have they done for each fix? Replace the whole pump assembly, or just the seal in the original pump?
#6 | |||
The first one they changed at a service, next one I fitted, and I will fit the next one as well.
Going to see if it is covered under warranty. it was aftermaket from autopro. They sometimes are. Not good , new water pump every 25000 Quote:
335 kw of goodness
Buy the sound of it, you have had a run of dodgie pumps, it would suprise me that a forth one would be a lemon..
Are you using nulon coolant?
It's the only nulon product I don't use as i found it makes leaks appear where they never have before. |
dont know if this will help but you might try some water pump lubricant in the coolant, ...... i`m wondering if the radiator has good coolant/inhibitor in it?? , i bought a pump (reco) for my truck .............the impellar came of while idling
#10 | |||
Back to Le Frenchy
Had to put a new water pump on mine with the engine rebuild as mine was looking like it was about to go.
Could be just a bad batch...
My original one let go at 60,000 kms, which i was very surprised with, replaced it with a generic one and has been good so far 20000 kms later. maybe you should look at a better quality one, or check for other issues with your cooling system, could also be a bit of crap floating around in there, what coolant are you using? |
#12 | ||
Where to next??
Is it possible to do away with the mechanical pump???
I once found a web site that touted a small horsepower increase (like 4-6kw, or was it HP?) when you removed the pulley for the pump and placed an electronic water pump in the system somewhere connected to a thermostat??? But either way if yours is leaking that has to be fixed anyway.... |
On older cars with traditional V'd belts, repeated waterpump failure was usually a sign of overtight belts. On a modern serp-belt I'd doubt this is the problem, but might be worth checking if the same person is installing each pump
#14 | |||
200 kw's at the wheels would have noticable change...Good effort....Wait until it loosens up, go burnoff some GEN3's.
#15 | ||
Thanks for all the replys.
Have a new Powermax water pump, 2yr warranty, New coolant ready to install. 42 degs temp here today, makes it hot in the shed. Have been working an XBGS, oringinal, 302 4 speed, white gold stripe.. Very oringinal...Was a Dealer demo in its day, Clothe Trim, A/C, Rear demister, driving lights. with Books.....Been off the road for years. For sale too if anyone is interested, absoletly NO Rust. |
#16 | ||
You wouldn't happen to have uinder drive pulleys would you, I've heard they sometimes give premeture failure due to it spining more times then it would from factory.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto ![]() Soon to be painted running a 4.0ltr v6 ![]() See the build here http://www.fordforums.com.au/showthread.php?t=11388068 You Have Freedom of Speech Just Choose to Remain Silent |
#17 | ||
Silhouette AU1 TS50.
The AU 220kw are underdriven from factory.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
#18 | |||
#19 | |||
#20 | ||||
Back to Le Frenchy
#21 | |||
#22 | |||
Ive checked a while ago and they list the same one for all of them, one piece pully balancer. |
