Old 30-12-2014, 09:35 PM   #1
bigal74
Default Conversion to electronic ignition
Howdy fellas, new guy Al here again. Looking at replacing the points/condenser in the dizzy on my 1600. Some questions:
Can anyone identify the type of dizzy from the attached photos or do I need to pull it out to confirm?
Are the Accuspark conversion kits any good or are there better options out there?
In the long run are the conversion kits as effective/reliable as changing out the dizzy for full electronic versions?
Thanks in advance.
bigal74 is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2014, 10:38 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Conversion to electronic ignition
Hi. Lucas dizzy, bosch points number is GL19(v), cant remember the lucas or repco number. Used in most lucas dizzys from the early 60s to the mid 70s. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 31-12-2014, 02:06 PM   #3
dirty hands
Over Thinker
dirty hands's Avatar
a good auto electrician should have the conversion dissy or kit
bosch conversions also
lucas ---- http://www.accuspark.co.uk/
http://www.accuspark.co.uk/fitting_guide.html
old blog start date 2011 now at 2014
http://blog.simonbbc.com/electronic-...ignition-kits/
not sure if you have to upgrade the coil for it
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2014, 10:22 PM   #4
freeo75
I used the Accuspark conversion kit for 1600 escort and it worked well - make sure you buy the right one for the distributor you have though! I also bought and used an Accuspark electric distributor for a moke I had which came with a new coil too.
Your dizzy is probably worn so I'd say spend a little extra and upgrade the lot
freeo75 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2015, 05:32 PM   #5
bigal74
Thanks freeo, I am leaning towards replacing the complete dizzy cos as you've said it's old and probably a bit tired. I'll give the bloke from Accuspark a call next week and have a chat with him.
Old 01-01-2015, 09:00 PM   #6
freeo75
It was a while ago but I reckon it was less than $150 for the distributor and coil!
Old 01-01-2015, 09:34 PM   #7
39ClevoUte
39ClevoUte's Avatar
http://www.autosportlabs.net/Megajolt_Lite_Jr.
Check this out, it's not that expensive and is 1000% better than a dizzy. Have a good look through the pages and user areas. I've had one on my V8 Clevo for 4 years and haven't missed a beat, makes tunning a breeze and performance is maximised.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2015, 09:43 PM   #8
39ClevoUte
39ClevoUte's Avatar
http://www.autosportlabs.com/product/megajolte/
Old 02-01-2015, 08:10 PM   #9
bigal74
Thanks for the ideas fellas. 37clevo thanks for the suggestions but I think all that gear is a bit radical (especially for technologically-challenged me). I really just wanted to get rid of the points and condenser due to access dramas, and had read some good things here and on other sites about the Accuspark setup. Cheers
Old 02-01-2015, 11:36 PM   #10
iana
Hi bigal74
I replaced the whole dizzy with an Accuspark unit from the UK & am very happy with it. As someone else has stated, make sure you have the correct coil. I also ordered mine with the side entry leads cap & if I did it again, I would keep to the top entry as per standard. Due to all the hoses & leads it becomes a bit of a nightmare on my auto Capri. If you want some pics & read how I fitted it, have a look on my blog:
http://fordcaprichatter.blogspot.com...max-results=50
9 Dec 2013 post)
Have fun
Ian (oldcapriman)
iana is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2015, 10:02 PM   #11
bigal74
Originally Posted by iana View Post
Hi bigal74
9 Dec 2013 post)
Have fun
Ian (oldcapriman)
Hey Ian thanks for the info that's all really handy. Oh, and by the way, your blog rocks. you do some nice work.
