Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
22-01-2007, 07:38 PM | #31 | |||
Back on the road
You can factor that lag into your shift strategy, and with only a little bit of effort, it will be changing gears when you want.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
24-01-2007, 02:17 PM | #32 | ||
Oops, I slipped....
Just to get slightly off the original topic here.
If you have a G-Tech Pro RR (or whatever they're called) that can be plugged into a PC, do an acceleration run from low RPM to the redline in each gear and graph the acceleration and speed for each gear. Then overlap the 3/4 lines on a single graph, and look where each gear accelerates less than the next gear (IE the lines cross over), that's where the perfect shift point is.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
24-01-2007, 03:06 PM | #33 | ||
Smile
Funny you should say that because I ahve the ss model (same as rr but no download) and its telling me some interesting facts. My peak power rarely hits above 4800rpm.The peak rpm point of a car is dictated mostly by intake and exhaust manifolding.at 4800 rpm peaking power there seems to be something choking airflow and power above this.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
