has anyone had problems with the radiator leaking up the top due to rust on both sides.is this a common problem on au fords. should it be replace with a new one or a good second hand one. cheers
Flairs - Truckers Delight
Yes, old radiators can rust and leak, especially if you haven't been using inhibitor.
Just replace it with a newie, slide on down to your local red devils and they'll fix you up Shouldn't cost more than about $300 fitted
Yep - Natrad bloke told me 9 out of 10 cooling system leaks on AUs were caused by corrosion in top corners of radiator core. Barsleaks stopped mine in the short term, but a new radiator is so cheap ($130 delivered with a 2 year warranty) its not worth stuffing around with a 2nd hand one IMHO.
#4 | |||
#5 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Do a search on Fleabay adrads for$130 deliverd
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Sales Representative
Aluminium corrodes very quickly compaired to brass.
With less maintenance than required, amonia levels increase very quickly. High amonia levels increase corrosion levels quickly, thus creating leaks. My suggestion would be a good brass core radiator and a good amount of cleaning.
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
a lot of radiator problems are caused by no or incorrectly mixed inhibitor make sure you use a good inhibitor and you'll get more life from your radiator and the rest of your cooling system
[SIGPIC][/SIGPIC]
#8 | |||
#9 | |||
#10 | |||
#11 | |||
#12 | |||
#13 | |||
#14 | |||
there are specialist around who will make custom brass tanks but take lots of $$$$$$$$$$$ with you
[SIGPIC][/SIGPIC]
#15 | |||
