Howdy to all,
RE: EF Fairmont Ghia (1995) Earlier this week as my wife drove off to work .... I noticed the passenger-side Brake Light was out ? Thinking it was likely a faulty bulb - I got a couple of new ones (12V 21W) with a view to replacing the BL bulbs - as a pair. Well... as it turns out, the existing Bulb is OK - so I then checked the Fuse ? No problems there either - fuse is Good. I checked the BL Switch on pedal, then realised if BL on parcel shelf and drivers side were working - then Switch must be OK too. So my friends, I am now at a loss - as to how to proceed from here ? What could this be - and have I missing something obvious ? All help appreciated... would be nice to get this fixed today. Regards, Larry |
Hi. The brake light bulb on falcons is not just a single filament 21 watt globe but a 12 volt 21/5 watt globe with two filaments in it, one for the brake light function and the 5 watt filament for the tail lights. Check those globes again. Cheers MD
#3 | |||
The Rear Light cluster on EF Fairmont's have a dedicated Brake Light holder and therefore a dedicated bulb... which is 12v 21W. |
#4 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
The rear tail light assembly on a 1995 Ford EF Fairmont has 3 bulb holders - 3 globes. 1. Single Filement Reverse Globe/Light 2. Single Filement Indicator Globe/Light 3. Dual Filement Brake/Parker Globe/Light Larry - Question- does the Parker light work and the brake light doesn't? As it's the same globe - if the Parker works then the globe is faulty ![]()
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
meh.
![]() Join Date: Jul 2010
passengers side brakelight is dual filament.. one for the parker stop lights, and the other for the brake lights.
Check the contacts and make sure they aren't touching eachother inside the globe holder
Dear Foxtrot, Sorted & xrghiawagon,
A THOUSAND APLOLOGIES !!! Silly me.... changed & checked the wrong bulb ? The Brake Light bulbs are INDEED dual filament (12v 5W/21W) I'm off to Repco now..... to get the correct bulbs.... :o) Thank you all - for your patience Best regards, Larry |
Most welcome - forums are here to help
Hi. No problems, glad its fixed. Cheers MD
meh.
Welcome..
