27-10-2005, 09:26 PM | #1 | ||
Parts bin special
For the third time in as many years, my right rear power window has let go on me. The last two times, it was a case of a gear slipping off the end of the shaft. Both times I took it to the mechanic. This time it seems to be the same problem, but this time I want to try and fix it myself. Has anyone had the same issues, and is there any way I can get the gear to STAY ON! I am sick of it. It happened when I was going to wind the driver's window up but accidentally hit the wrong switch. Since the right rear was already up when I hit the switch, it tried to force it and it had nowhere to go. The thing is, every time I make that small mistake by hitting the wrong button, it wrecks the rear window. Is there a way to idiot-proof it, so I won't have to worry in the future?
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
27-10-2005, 10:01 PM | #2 | ||
lol mate, I think the only way is to be more observent in what you are touching :P
I had the same problem with my front left window, but took it to local mechanic and he did the trick so I found that this was the easiest way While we are on the same topic, my windows get stuck in some parts, I was thinking of "lubing" them up to make them slide up and down easier (these are electric windows btw) but does anyone have any product in mind to get the job done? |
27-10-2005, 10:13 PM | #3 | ||
geez bloody power windows in fords.... mine are shocking in the ef, especially when its wet, icant even get the passenger front to go up half way.
27-10-2005, 10:14 PM | #4 | ||
i was told by someone to use vaseline.......... im not too sure about this though??
27-10-2005, 10:18 PM | #5 | |||
Parts bin special
27-10-2005, 11:44 PM | #6 | ||
get some EB2-EL rear ones. the EA uses a weird setup for the rears and are very weak in design. the later ones are much better. (but stilll stuff up :P)
28-10-2005, 12:03 AM | #7 | |||
Parts bin special
28-10-2005, 12:12 AM | #8 | ||
on other posts about windows silicon spray gets a mention on rubbers, might be worth a go
28-10-2005, 12:28 AM | #9 | |||
Bad Music and Litre Bikes
silicon spray, and powdered graphite.
Thats what i use on the LTD, and on the electric tailgate window in the XY
XY Wagon - NAKED! Quote:
28-10-2005, 01:52 PM | #10 | ||
To stop windows from trying to go up when already up youcould fit a switched relay into your window electrics so that when window reaches top of run it cuts power to window motor and will only kick back in if you press down.
Would be a lttle tricky to design but fairly basic in operation |
28-10-2005, 02:08 PM | #11 | |||
Parts bin special
In the end, I went to take off the door trim and realised that I need an allen key for the door handles. Pity all my allen keys are all back at Gippsland. Guess I'll have to buy another set of them. To make things even worse, it appears my aircon has leaked out all the gas again! When it rains, it pours.
28-10-2005, 02:42 PM | #12 | ||
Think I'm glad I don't have power windows! Gotta say though, Mum's got a 1993 Camry Vienta with power everything including windows, and I don't think they've ever had a problem...
Bloody Fords :P |
28-10-2005, 03:43 PM | #13 | ||
likes falcon's
i think its design problem as john said, my ea used to always screw up only on that side!!! i suppose it doesnt get used much...
www.carhubsales.com.au |
28-10-2005, 04:02 PM | #14 | |||
Parts bin special
28-10-2005, 06:03 PM | #15 | ||
power windows are good and bad, when you have them they suck cause they dont work, but when you dont have them u need them
29-10-2005, 09:22 AM | #16 | ||
Bseries Moderator
i love my good old window winders :P i had power windows in my old xf ghia. i will try to avoid ford power windows from now on. my old man has an au and a friend has one too and the power windows on them are both pretty much cactus
29-10-2005, 06:08 PM | #17 | ||
sorry to hijack the thread but my drivers side power window is very slow to wind up til 2 thrids then speeds up to "normal speed" for the last third.
any Ideas? I may have hijacked but say one thing, the manual winders in my old ef were that hard to wind the window up that the missus wouldn't even bother with the windows. good old aircon! |
01-11-2005, 04:29 PM | #18 | ||
I am having problems with my el falcon electric windows. The window seems to drop down at the front when winding up and causes it to jam up and go up really slow. Just wondering if anyone else has had this problem and what parts do I need??
01-11-2005, 05:04 PM | #19 | ||
yea mine does exactly the same, have to pull it back toward the rear of the car in order for it to go up the rest of the way. I took it into ford ages ago, they used powdered graphite, it helped for a few weeks then went back to how it is now.
01-11-2005, 05:20 PM | #20 | ||
rofl copter
yeah my lhf window turns clockwise a bit when going up, but i know what it is just too lazy to fix it :P it would have just lost the bolt that holds the window on the bracket or they are loose
GQ patrol.
.... thats all |
