I have an au1 ute and i am looking at a 2000 model au fairlane for parts, i want the 5L, the dash, leather interior, door trims and whole front end on my ute, what do people think of how possible this is? Will i need to swap the wiring harness from the fairlane for all the dash gear?
I think it will be an interesing combo if i can pull it off |
Pro Street Au Ute
Easy swap, good luck.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
All you need is time.
#4 | |||
Just another mock-up..
By the looks of your avatar, it's true..!! haha On another note, I saw a ute that looked like yours a while back in front of brumby's heidelberg.. Was it yours..?
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
You found me.
#6 | |||
Looks great in the flesh mate..! Nice job on it..
who do you know around there.
Well essentially this is what I am doing to my wagon except only without the extra seats etc. Should all be possible, not too sure how much of the wiring would have to be changed though. Being a series 1 I would expect you would have to change a fair bit of wiring over.
Physically everything will bolt straight in though. Entire front end, dash, heaterbox, seats, door trims etc.
Toy Car Build |
If you need help I'm there.
thanks for the advice guys, the fairlane i was going to look at doing it with was not in very good nick as there was front end damage and the leather was well worn so i will keep my eyes out for another
i got a complete fairlane front if some one wants it
TE50 T2 AU2 GHIA |
#12 | ||
A couple of questions, firstly what must be done with the rear wiring harness as in door lights on the dash or do we just remove ans forget?
Are the brakes from a series 1 nu different from a a serries 2 ute because my ute nearly rips the wheel out of my hands when brakes applied on a steep incline? Do we need to change all the wireing harness's ( staying with the six) or just the body harness and bcm? And to run the vct intech do i only need to swap motor and ecu? |
my current progress
#14 | |||
#15 | ||
The door light on the dash will turn off when you disconnect the switch. The front brakes on S1 are one piston calipers S2 has two piston calipers. Use the fairlane wiring harness and graft at the first plug near the right rear wheel,the tail lights have the same colour coded wires.
#16 | ||
I will pm my phone number
#17 | ||
Good start they were the same colour.
#18 | ||
Wish i had your work shop, motor and box are out now, pull the brake lines and abs module remove the nu shell and wait till xmas when ive got a couple of weeks off to do the convo.
#19 | ||
#20 | ||
