Old 26-08-2007, 04:18 PM   #1
Micktor's owner
Default Head unit and idle
Firstly thanks dirty hands and others for radio/wiring info from previous posts ... much obliged.
But I've hit a snag getting the head unit out of my 88 Laser. I've taken out the screws from behind the ashtray, pulled the fascia forward a few cms, removed the screws in the side of the radio, but the damn thing moves up and down but not out. I'm sure I'm missing the simplest thing, anyone got any clues for the clueless?
PS- "Q. driving it the damn thing just stalled. It is possible to start it when it is warm but it won't idle."
''A. the telstars had problems with vapor lock when hot''.
''i found the problem to be loose/disconnected vacuum hoses, probably best to check all vacuum hoses you can readily see for any loose connection''
My auto Laser idles roughly when it's warmed up, same prob as the Telstar?
Micktor's owner is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 02:20 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
PS- [I]"Q. driving it the damn thing just stalled. It is possible to start it when it is warm but it won't idle."
radio unit may need a screw and a spring washer to hold it in place
then retighten
idle problems same as telstars .............. yes
My car goes Brumm Brumm
