Old 12-11-2019, 02:32 PM   #1
Dr Terry
Default Cortina Model ID Code
Hi Guys.
I am currently compiling a model code list for Aussie Fords & am having difficulty finding model codes for Cortina, especially TC to TF.
The codes that I'm referring to are the 5-digit codes stamped on the body ID plate. For example a 1968 240 2-door has the code 12814, while a 1969 GT has the code 12938 & so on.
Most of this info is in Ford parts catalogues & other Ford literature, badly sadly usually not in workshop manuals.
Does anyone on here have a list of these codes or have access to the relevant manuals ?
Thanks in advance.
Regards Dr Terry.
Dr Terry is online now   Reply With Quote Multi-Quote with this Post
Old 12-11-2019, 05:03 PM   #2
roKWiz
Cabover nut
roKWiz's Avatar
Default Re: Cortina Model ID Code
Do these help sorry about the size. From TE TF fiche.
Old 12-11-2019, 05:34 PM   #3
GTLEGEND
Here you go, from 1962-1982..
Cortina 62-65 Model Codes.pdf
Cortina 65-67 Model Codes.pdf
Cortina 80-82 Model Codes.pdf
Cortina 71-74 Model Codes.pdf
Cortina 74-77 Model Codes.pdf
Cortina 77-80 Model Codes.pdf
Old 13-11-2019, 04:05 PM   #4
Dr Terry
Thanks guys, that will fill quite a few blanks.
While I'm at it, does anyone have these numbers for late XF, XG & XH commercials.
Dr Terry
Old 13-11-2019, 05:21 PM   #5
GTLEGEND
As requested..
XF Falcon Model Codes.pdf
XF XG Model Codes.pdf
XH Model Codes.pdf
Old 13-11-2019, 05:54 PM   #6
Dr Terry
Thanks again you guys are great.
There seems to be some anomalies in the TC model numbering.
Ive recorded a few codes from later series TC Cortinas that don't appear on that list.
When you look at them, there must be a series of missing models numbers in 1972 & 1973 but the above list has all TCs using a 1971 code. This doesn't happen with any other Cortina.
Does the parts catalogue agree with the above list (Cortina 71-74) ?
Dr Terry
Old 13-11-2019, 06:21 PM   #7
Dr Terry
As requested..
Attachment 102214
This list seems to finish 10/86, with no mention of late XF commercials or XG.
Dr Terry
Old 13-11-2019, 10:04 PM   #8
GTLEGEND
Yeh, you are right, might have to check the hard copy over the soft copy. See what we can find out..
Old 14-11-2019, 03:48 PM   #9
roKWiz
Cabover nut
roKWiz's Avatar
Dr Terry
On the part catalogue I have states from 88.
XF GL panel van model code 45683
My 93 XF GL panel van model code is 45018 !!
Old 14-11-2019, 04:00 PM   #10
Dr Terry
Sorry that was my 'fat' fingers. My catalogue also says 88, not 86.
Dr Terry
Old 14-11-2019, 04:03 PM   #11
Dr Terry
Does it say 45018 or 45081 ??
Dr Terry
Old 15-11-2019, 08:48 AM   #12
roKWiz
Cabover nut
roKWiz's Avatar
Dr Terry
Ooops, 81
Old 15-12-2019, 02:34 PM   #13
GTLEGEND
Some more codes that I have found Dr Terry..
89 XF Commercial: 45671 Std ute, 45681 std van, 45674 GLS Ute.
90 XF Commercial upgrade: 45071 GL ute, 45081 GL Van, 45074 S ute.
What else are you still missing?
Old 17-12-2019, 09:34 AM   #14
GTLEGEND
Left off XG:
GLi Ute: 45371, S Ute: 45374, XR Ute: 45375 and Gli Van: 45381.
Have we covered everything?
Old 18-12-2019, 08:22 AM   #15
Dr Terry
That looks like it for now.
Thank you
Dr Terry
