![]() Noticed yesterday a bit of banging when going over a hump, figured it was something in the boot, then tonight saw my tail pipe was seriously sagging. Looks like I can get a complete rear muffler assembly on ebay, but how difficult is it to fit? Can't seem to find any exhaust related HOWTOs on the site. I have a Gregory's manual but it's pretty vague. Any tips appreciated, bearing in mind this is probably the original nearly 11 years old exhaust. ![]() edit: 2002 AUIII Fairmont, standard suspension I believe. |
meh.
![]() Join Date: Jul 2010
IMO, I'd just buy a new catback... If it is the original exhaust, I'd just swap the catback out at the same time. Can be had from $170+ on ebay...
Something like this?
http://www.ebay.com.au/itm/STANDARD-...ts_Accessories What sort of problems am I likely to run into when removing such an old exhaust system? And just out of interest, is it easy to see if the muffler was blocked once I remove it? I've had something wrong with the exhaust for a while, and have recently noticed that the engine note has changed back to the way it used to be... possibly because of that nice rip in the pipe letting the exhaust get out! |
meh.
That'll do the job fine. FYI, Tuff Car Parts are a Forum Sponsor, so hit Justin (Private9) up for a forum members discount
![]() Probably just the front bolts being tight and rusty (use 6 sided sockets/spanners, and some freeze and release) and the hangers (3 of them) being old and cracked..
Like any exhaust change, it can be a **** of a job. The most difficult thing is removing that section of exhaust where it joins onto the central muffler. If it is rusted solid then its an angle grinder job.
The biggest shitter can be when, after finally getting the ****** off, you discover that its not standard diameter. I tend to agree with XRGW. Check your whole exhaust carefully, and if the main muffler is also on the way out, change it all from the cat back. It is two very easy bolts to remove and a gasket, then you can hack the rest into pieces. The only other challenging bit can be that last hanger you can see in your first photo. You need to push the exhaust up and squash the rubber, so you can pull it off the flat hook. (Forget trying to pull the hanger out of the rubber. They LOOK like they should come out easy but don’t.) If buying off eBay, be careful you get the right one. Fairmonts have that extra muffler at the end, but my other AU’s did not. (Could just be cheapo after market jobs?)
Time to Make the Hippies Cry Again |
meh.
All cars should have a muffler and/or resonator on the rear to be legal. I'd say someone just did a quick cut and shut to remove a rusty muffler...
#7 | |||
http://www.ebay.com.au/itm/2-5-CAT-B...ts_Accessories Wondering what I should do in the meantime, tie up the muffler with some wire (but risk the pipe breaking completely), or just leverage the whole thing off? Or not drive the car at all? |
as said above get a new cat back system, once they get to this stage you can repair it but you'll keep repairing it as other sections break.
you can go standard as mentioned above but for a bit extra you can get a 2.5" redback system that will sound better and perform better http://www.ebay.com.au/itm/REDBACK-2...item27b43a6983 as mentioned ask him for a forum discount
[SIGPIC][/SIGPIC]
#9 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#10 | |||
Boost Addict
You need to meet noise regulations and emission regulations, how you achieve this is not stipulated. If it is by the means of a turbo cat and center muffler, then you are just as legal as having a rear muffler/resonator.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
meh.
Well tell that to the EPA, had a few warnings for no rear muffler/ resonator...
#12 | ||
Boost Addict
must be a NSW thing then ...
most aftermarket "sports" system cut the rear muffler out and are ADR approved.
There are two joints in the factory 6-pot system, shortly after acquiring my AUII Fairmont, I had the local specialists cut off the rear muffler and replace it with a 'hot dog' (straight through) muffler.
It was relatively cheap and the car now sounds good (not at all loud) and the hot dog will last forever (well, almost!). Had that fitted 10 years ago in September, and its still sounding/looking good! |
#14 | |||
I would not be driving it in that condition, not only do you risk a lot of nasty stuff coming up into the cabin, but risk getting the car stickered. If you are waiting on the parts, and must drive, I'd recommend a "muffler bandage" as a temporary measure.
#15 | ||||
So is a 2.5" redback or supercat a reasonable system (bearing in mind it is budget) |
#16 | ||
Some more pics...
![]() Here's the little wire loop I did to help support the muffler (the cracked area seems to be holding most of the weight) ![]() This is worse than I expected. You can see daylight! ![]() Sanding the pipe preparing to apply the patch, I realise it's more than a crack, the whole top has caved in. Can only see this part by taking a photo with my phone. ![]() The connection to the front muffler isn't looking so great either. So I'm replacing everything past the cat, but the thing I'm wondering, is the cat likely to be rusted out too? |
#17 | |||
AU DIE HARD
Gees Man do ya self a favour and piff the whole thing before the fumes KILL you. If your light on cash just go to the wreckers
#18 | ||
64 Deluxe 4 door
![]() Join Date: Jun 2007
where ya at mate?
XM Deluxe FG XR50 BA Pursuit Ute |
#19 | |||
