Old 04-05-2021, 11:16 PM   #1
Edxr6
Default Oil spray XR8 220
Guys,
I am getting a very fine spray of oil on the engine side of the air box, adjacent from the power steering pump. Definitely not coming from the high pressure hose
or the top nut on top of the pump, the pump pulley seems dry as well. I have sticky taped a piece of white paper on the side of the air box to ascertain the colour of the oil to identify if it’s the power steering oil or engine oil with colour difference. Unable to tell at this stage as the spray is very faint. Waiting for a more build up of oil on the paper. Any ideas?
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2021, 12:01 AM   #2
T3rminator
T3rminator's Avatar
Default Re: Oil spray XR8 220
Check crank pulley / harmonic balancer. Oil can leak through the pulley and spray onto the box. Check straight after a spirited drive, you will see marks on the pulley if that is it.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2021, 08:58 PM   #3
Edxr6
Thanks T3ermintor, I will check that.
Regards
Old 05-05-2021, 10:39 PM   #4
orsm8
orsm8's Avatar
I had a new AU3 xr8 in 2002 and I had similar problem it turned out it was an oil cooler that was leaking. Car had only done a few hundred kilometres.I hope that helps
orsm8 is offline   Reply With Quote Multi-Quote with this Post
