08-01-2006, 02:03 AM | #1 | |||
AU DIE HARD
Hey gang any help or tips on ajusting hanbrake on my Aull XR would be good .
Iam pretty handy with spanners, but if it easyer to get it done at the Ford shop thats ok too thanks whoosha.......
08-01-2006, 03:30 AM | #2 | ||
Boost Addict
start adjusting the little nut under the handbreak shoe, very simple and quick
if that adjustment is not quite enough you have to adjust it on the rear axel
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
08-01-2006, 01:57 PM | #3 | ||
FTF Club Moderator
Slide the handbrake shoe up and you should see a 10mm IIRC nut tighten that up. As Evil chief says tighten it up on the rear axel. To do this loosen the nut under the shoe, then go to the rear axel and tighten. I believe it is on the drivers side of the axel near the disk to tighten.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
08-01-2006, 03:22 PM | #4 | |||
AU DIE HARD
thanks guys about to go + do it
Whoosha
17-01-2006, 04:55 PM | #5 | ||
Hey mate,
I have herd that if you drive with your hand brake on they are really flimsy and break. Ford done mine for about $30. Cheers. |
