Old 19-02-2012, 04:10 PM   #1
rmack
rmack's Avatar
Default Help Name This Part Please.
Okay I know what this part is for, but I do not know its name.
Today I changed all the coolent hoses, Water Pump and Heating Tap but on closer inspection of this unnamed part, I feel I should replace it too.
So if you can name it I can buy it.
Thanks,
Edit:Spelling
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 04:32 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: Help Name This Part Please.
That's the pipe that feeds the heater. I'd guess and call it the heater inlet pipe. There's a corresponding one on the other side of the block that feeds back into the water pump. That I'd call the heater outlet pipe........ but I don't know what the parts catalogue would list it as.
Why do you think it needs changing anyway?
Bushbasher
MINE- AUII Forte
Old 19-02-2012, 04:39 PM   #3
rmack
rmack's Avatar
Bushbasher
Thanks BUSHBASHER
The reason why I want to replace it, is that it is badly corroded on the heater tap end,
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 19-02-2012, 05:54 PM   #4
rmack
rmack's Avatar
Okay I found this in the parts database
Part #EF 18C266 A
Description: HOSE ASSY HEATER
So the next question. Is the EF part the same as an VCT AU????
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 19-02-2012, 06:32 PM   #5
rmack
rmack's Avatar
Part #EF 18C266 A
Wrong Part Number
Part #EF 18696 A
Description: TUBE HEATER INLET
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 19-02-2012, 06:39 PM   #6
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
EF and AU share the same part - I'm running an EF thermostat lower heater pipe on an AU VCT engine..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2012, 11:18 PM   #7
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
i have a brand new AU one sittting here as a spare, part number WR2A 18696 AA
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 11:36 AM   #8
rowan194
Just out of interest...what's one of these worth? Mine had a minor leak at the thermostat housing end too, I globbed it up with some form-a-gasket type 2, but I don't expect the fix is going to last too long.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2012, 10:01 PM   #9
rmack
rmack's Avatar
I am going to stop by ford tomorrow and get a price. When I do I will pass it on.
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 21-02-2012, 02:02 PM   #10
4ford
That heater pipe you'all are referring to has a rubber seal fitted at the thermostat end. This seal can be bought very cheaply (even at Ford dealers), and get replaced.
I replaced mine around a year ago, after it started to leak, increasingly!
Cheers,
4ford
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2012, 05:44 PM   #11
rmack
rmack's Avatar
Mine is leaking at the other end. The pipe has corroded through and has a small fracture which leaks under pressure.
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 21-02-2012, 10:48 PM   #12
rowan194
I replaced the o-ring on mine, still leaking. :( (until I put the gasket stuff around it)
Old 22-02-2012, 10:57 AM   #13
rmack
rmack's Avatar
Picking up the part today from Brad Garlick Ford (Sydney) Cost around $65.00 inc GST
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 24-02-2012, 02:26 AM   #14
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
The pipe is exactly the same from EA-AU. Not sure about part numbers, but fitted an EA one to an AU s2 ute a couple of weeks ago....
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2012, 08:33 PM   #15
rmack
rmack's Avatar
Fitted the replacment part today. As stated above $65.00 inc GST
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
