RIP...
Morning,
How many (any?) of you guys fitted 245/45/17 instead of the standard 235/45/17 to your standard rimmed XR8's? The diameter is increased by 9mm, which is 2/5ths of bugger all, and only 1mm off the standard 245/40/18 size fitted to Rebel and T3's. If so, what were the changes felt? The price of these are only a small amount above the 235 these days, and an extra 10mm width shouldn't do any harm to the handling, and definitely won't do any harm to looks. It should help overall grip slightly. The effect on gearing will also be negligible. Thoughts... BTW, the lip is already rolled on my front guards, so catching on the lip won't happen.
. Oval Everywhere... |
Next upgraded Mk1 Leopard
Yeah catching the lip is a bugger, a wider look is always better.
I've got 235/45R/17 on the XR8 (came with the car) so can't help. UK ![]()
Sick Puppy
Not sure 100% how it would apply to a 17 but I know a 245/45 18 on a BA XR8 rim fouled on the top wishbone and balljoint on my missus Ghia when we fitted one.
You couldn't even turn the wheel. |
#5 | |||
RIP...
A 245/45/17 is the same as a 245/40/18 (almost).
. Oval Everywhere... Last edited by Raptor; 08-09-2014 at 01:53 PM. |
I ran the 245 on my wife's xr8.Standard xr 17 wheels.
Issue was it collected the front guard lip over a heavy bump with lock on. Went back to 235 for this reason. My pursuit with the 18 run 245 and also have issues with lip if not careful. Cheers Dazza |
#7 | |||
RIP...
How different did it feel with them though?
I personally couldn't notice any difference but I don't drive it much.
They looked better on the rim. Sorry missed the "all ready rolled" comment. |
![]() Join Date: Nov 2011
#10 | |||
RIP...
I have the 18's on my own ute, but asking about my sedan. Reason being, sometimes in rare(ish) cases, a slight increase in profile, etc, can disturb the balance/dynamics of some cars. I highly doubt that our XR8's are one of those sensitive cars, but I thought I'd ask if someone has used that specific combination anyhow.
. Oval Everywhere... Last edited by Sox; 08-09-2014 at 03:18 PM. |
#11 | |||
CNC fixer guy
I have the standard 235 45 17 on the front and 255 45 17 on the back of my au lane and its feels the same as the 235 45's. Probably slightly slower off the mark but the speedo is now spot on at least. I think it is as wide as you can go legally on the 8 inch wide rim. the rolling diameter is similar to the standard 16 inch tyre fitment. cheers.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
#12 | ||
LIFELONG DJR SUPPORTER
Sox,
I had a set of 245 on my factory 17's and they did rub slightly, on the front inner guards when compressed and turning, and on the read under extreme compression. I wasn't so concerned that I replaced them before they wore out though. Mike
