Old 20-11-2005, 02:18 PM   #1
stockstandard
Default Downside of a cammed engine
Reversed out my driveway yesterday, went for the bakes and there was nothing there! Found the handbrake just in time to avoid mounting the curb.
Here is what caused the problem:
My guess is after 18 months of a lumpy enigne pulling on the vacuum line the booster has decided to finally give up.
Anyone with the plastic booster found on later e-series might want to check out theirs and maybe add some support.
Old 20-11-2005, 02:24 PM   #2
niko
likes falcon's
niko's Avatar
can ya get a longer hose?
www.carhubsales.com.au
Old 20-11-2005, 02:25 PM   #3
RED_EL_XR8
RED_EL_XR8's Avatar
My guess is your guess is incorrect. Morel likely Heat plus material flaw.
If your engine had enough vacuum to distort the Booster it would have sucked your air filter through the butterfly!
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2005, 02:32 PM   #4
stockstandard
Im not saying vacuum distorted the booster. At idle the engine is rocking slightly left-right and is pulling on the hose, which is bending the connection back and forth. I think this weakens and eventually cracks the booster around the connection.
Going to replace the booster and use a slightly longer vacuum line and anchor it to the firewall to stop movement.
Old 20-11-2005, 02:39 PM   #5
RED_EL_XR8
RED_EL_XR8's Avatar
That'd be wise.
Old 20-11-2005, 02:57 PM   #6
stockstandard
would have been wiser to have realised there was a problem and fix it before it broke. Ahh well.
Repco want about $350 for a new booster. Hope I can find one cheaper elsewhere!
Old 20-11-2005, 02:58 PM   #7
Hippy
Man from Ironbark
That'd be wise.
Hippy is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2005, 02:59 PM   #8
Hippy
Man from Ironbark
Wreckers...
Old 20-11-2005, 03:01 PM   #9
woodstock_rocks
That'd be wise.
you got : enough vaccum to distort the booster?!?! BWHAHAHAHA
That sux about the booster standard, maybe a longer hose would give a bit more flex ..
Old 20-11-2005, 03:09 PM   #10
RED_EL_XR8
RED_EL_XR8's Avatar
You are in your own clue free zone! Any ownership is from complete lack of comprehension!
Old 20-11-2005, 03:14 PM   #11
stockstandard
"Cant we all just get along"
Maybe in the future ill just keep things to myself...
Old 20-11-2005, 03:32 PM   #12
EDXR8
EDXR8's Avatar
Sounds like a good idea, some people just don't have a clue and obviously can't read properly.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 01:58 AM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
agreed.
/me goes and checks brake booster
Old 21-11-2005, 11:49 AM   #14
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Same thing happened in my EF, and silicone won't plug the gaps either. I've been told AU ones fit, so there should be a constant supply in wreckers for years to come.
Athol Park charged me 50 dollars I believe for a replacement.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 06:49 PM   #15
galapogos01
eec tweaker
galapogos01's Avatar
go to the wreckers. you dont need the master cylinder.
mine split along the seam from extractor heat. common problem with the later, plastic ones, im told.
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 07:18 PM   #16
stockstandard
They charged me $65 today :(
Old 21-11-2005, 08:32 PM   #17
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
It's Old Age
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 08:56 PM   #18
wagon
i had probs with my breaks today and i think it mite be the same prob
i was at a set of lights and all of a sudden i hear this vacume noise
coming from under the dash and i have a realy hard break pedel
and pretty much no breaks.
is it a big job to change the vacume booster???????
cheers kylie
Old 21-11-2005, 11:25 PM   #19
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Its a very common problem with EF's, as Ford went to the plastic Booster.
i know of at least 12 people who have had the booster crack.
99% of these cars where stock.
I doubt the problem was cam related.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2005, 12:06 AM   #20
John_LS1
Originally Posted by Rollin
while you guys are all checking the health of your break boosters, check the hose for rubbing as well - OED666s vacuume hose was pretty much worn through from rubbing on the back of the rocker cover!
very true, mine was nearly through aswell, went to repco and bought some new stuff, was pretty cheap.
