18-11-2006, 09:27 PM | #1 | ||
AU II XR8
the car drives fine, but everytime the front left hand wheel goes over a ditch it makes a knocking sound. it was taken to a shop where they tested the supension, but they couldnt find anything. its deffiently there though.
any ideas? |
18-11-2006, 09:59 PM | #2 | ||
Mine used to make a knock in the front and my mechanic changed the D-Bushes and its gone, dont know if it may be them?
Lightning Strike 09 G6E TURBO Shockworks Coilovers - Inovit Speedys - Streetfighter Intake
19-11-2006, 01:53 AM | #3 | |||
19-11-2006, 10:31 AM | #4 | |||
Walking with God
Cheers GK
19-11-2006, 11:58 AM | #5 | ||
AU II XR8
ok thanks.
19-11-2006, 01:09 PM | #6 | ||
AU II XR8
is this another common problem with the AU, cause i also get the squeaks when its been sitting over night in the cold wether (5deg average)
19-11-2006, 04:57 PM | #7 | |||
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 19-11-2006 at 05:54 PM. |
19-11-2006, 05:50 PM | #8 | |||
Walking with God
I sprayed them yesterday with motorbike chain lube, much better than the thinner WD40 I used last time! Hey my 2000th post, cool! Cheers, GK
19-11-2006, 05:55 PM | #9 | |||
19-11-2006, 06:13 PM | #10 | ||
SS Grunt
AU2 has the 24mm bar.
The Beast has gone to a new home Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW I will also enter any part of the Forum I wish to enter. : |
19-11-2006, 07:31 PM | #11 | |||
Walking with God
I appreciate the pic. Now, my SR would have the 24mm bar right? Funny thing, these were replaced by Pedders in January, but I wonder if I damaged them a bit when I changed over the springs. I was concerned about the sway bar. Remember that conversation JC? I wonder if I wore the bushes a bit, they are after all the red hard plastic items, not rubber. Should I replace them you think, or just take them out and give them a good greasing up? Two 13mm bolts or such from memory. GK
19-11-2006, 08:12 PM | #12 | ||
SS Grunt
If they were replaced not long ago i would just grease them up, there is no reason they would be worn so quick unless they didnt grease them properly to begin with. But you will be able to tell when you pull them out if its just a grease or replacement needed.
Shaun
19-11-2006, 08:43 PM | #13 | ||
I think it may be the upper ball joint, you wont get any freeplay, it will be dry, Ford dealers have a special tool for lubing the upper ball joint.
19-11-2006, 10:18 PM | #14 | |||
19-11-2006, 10:39 PM | #15 | ||||
Walking with God
I'll pull them out and grease them up. Standard grease I assume? I have some Penrite grease (high boiling point) in the shed, I suppose that'd do. GK
19-11-2006, 10:48 PM | #16 | |||
19-11-2006, 10:58 PM | #17 | ||
guys when doing upper and lower balljoints i usually get a needle and inject the lube in you can get large syringes from chemist for around 6 dollars my backyard mechanic mates trick
DUMPED AU |
19-11-2006, 11:06 PM | #18 | |||
Walking with God
Cheers, GK
19-11-2006, 11:31 PM | #19 | |||
AULTD
Got any photos of you doing that? Do you inject from both sides or top and bottom? How far in do you have to get the needle, as there doesn't seem to be much room to get the needle in between to squirt the grease in |
19-11-2006, 11:33 PM | #20 | |||
AULTD
Sounds like it might be another GK "how to". I hope so as I am getting some knocking noises in the front suspension. |
