Need some advice please guys. I am going to upgrade my brakes on the s1 to the premium brake set up. What more do I need to buy? I believe all I need is the uprights and the swaybar and mounts. Is this correct. The s1 has abs if that makes a difference. I am guessing that I use my existing hubs. Any advice will be greatly appreciated in fixing Fords lousey brake design.
#2 | |||
Back to Le Frenchy
Make sure the SII premos have the gold coloured brackets that they bolt on to. If they don't you aren't going to be happy.
#3 | |||
Depends on what you mean by premium set up, ie if donor car is s1 or s2. I put premium brakes on my S1 Fairmont, but they're off a T1 therefore swaybar etc was all the same, I just swapped the uprights and the new calipers / rotors bolted straight on (no need for the bracket which s2 requires). If you haven't got the T1 uprights you'll need to basically do the whole s2 conversion, with uprights, lower control arms and swaybar, as well as getting the premo rotors and caliper (with, as russell mentioned, the mounting bracket needed for S2's). Hope that helps. I've got a premo brake set up pdf somewhere which is quite good if you want me to email that through or anything. Well worth the upgrade though, they're awesome!
#5 | |||
Boost Addict
do a search . there are a handful of write ups ... i have done a write up a while back (did this conversion back in 2002)
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
Red is nice Mark.
You are getting the brackets mate.
Twin T3's TE 50 #72 Blueprint & TS 50 #105 Blueprint ![]() |
#8 | |||
#9 | |||
#10 | ||||
Back to Le Frenchy
You won't know yourself with the premo brake package, I noticed a huge difference when I put mine on and I was only stepping up from the SII brakes.
Barra Turbo > V8
No more brake fade
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
