28-03-2024, 11:25 AM | #2 | ||
28-03-2024, 11:36 AM | #3 | ||
I’m sniffing at a late ‘00s 5-series Beemer for some people who are seeking a cheap car, they’re better value than standard VE Commodores at present when comparing year/condition.
2 users like this post: |
28-03-2024, 12:23 PM | #4 | |||
Less than 120000kms? Yes they are cheap - prob even cheaper for you as you know where to look |
28-03-2024, 03:09 PM | #5 | |||
I use brain. Not hip.
Giulietta has COMMON FAULTS AND FIXES Oil leak When you take off engine cover sometimes you can see a oil leak from PCV There is an O-ring that plays up sometimes Vlad his own one which is a fit and forget type Electrical Boot button might not work and lights play up If odometer STARTS FLASHING you have three days to disconnect battery Sometimes on the early cars, the wiring loom on the hatch breaks and needs to be replaced Vlad has a replacement which ha says is much better COOLANT TANK Replace every 4 years when timing belt is done Replace return line to coolant tank st same time. 10mm heater hose GENERAL To adjust the clock or the headlights the buttons are on the right hand side of the steering wheel If the tyre pressure monitoring system alarm comes up pump up your tyres and reset the system on the special button to the right of the radio My car is fitted with one of those stupid start stop mechanisms that makes engine stop at the lights There is a little button in front of the gearstick. It is the one on the right. Sometimes the warning light comes up on the dash because the stop button isn’t working.. that’s probably because I turned it off because it’s stupid and I want Air Conditioning running BECAUSE Queensland. Turn the engine off at lights or when you stop and hold your finger on that button and then start the engine and it generally goes away first time. But sometimes it takes more than once I’m not quite sure why maybe I’m not doing it right I’m still working it out. Doorhandles The first one to go will be the drivers door handle. Angelo says it’s because Australians are too rough with it. You can buy replacement doorhandles about 20 bucks on eBay, but I think I would buy one from Vlad if I was going to get one. Mine os OK @ 115klms The other option is Alfa Romeo will very kindly sell you a whole complete door card replacement for about 400 bucks - no thanks. That’s about all that goes wrong apparently. The rest of the car seems bullet-proof, especially the motor which is very strong. There are also Diesel variants but I think they are Automatics and from what I can gather they often have too much torque for the Automatic and burnout the clutch The 1.4 petrol turbo has plenty of torque is a beautiful engine to drive That’s about it so far I love it. Talk about fun bang for the buck. These were $40k new. Steve |
28-03-2024, 02:14 PM | #6 | |||
T3/Sprint8
Got to accept a early costly divorce haha.... kevino, great for an affair, got to do it once lol Yer re the Pug GTi hatchs, for me about the only pug I'd ever consider. FairmontGS, my young wife came from Enmore, therefore our first property had to be close by so Petersham it was. The whole inner west was my realm visiting many workshops, great days, Annandale/Leichardt/up to Ashfield/Five Dock/Croyden Park - Frank Crotts Alfa. Incl FPM as mentioned, last of the mohicans.
28-03-2024, 02:35 PM | #7 | ||
Cabover nut
28-03-2024, 09:47 PM | #8 | |||
Oppressive patriarch
. Lamenting lost Australian manufacturing. BA RTV. |
01-04-2024, 05:00 PM | #9 | ||
Cabover nut
Reasonably straight and not much rust. 76 XB panel van $13K.
https://www.facebook.com/marketplace...tory_type=post
02-04-2024, 03:18 PM | #10 | ||
Cabover nut
Quite the oddball collection $300K for the lot in Denni. NSW
3 users like this post: |
