Old 08-09-2005, 04:10 PM   #1
sfr rob
sfr rob's Avatar
Default aftermarket CRUISE CONTROL
hey,
The price for a genuine cruise kit is about $500 or more..
i saw a cheap cruise set up for under $200 in a magazine advert.
would you reckon it would be "safe" to put one in or would you take the plunge and cough up $500 for a genuine kit?
just after some suggestions thats all!
thanks
Rob
Old 08-09-2005, 07:12 PM   #2
boodek
Ferret
If the one you're talking about is a "Command Control" unit, I'd be pretty confident fitting it. I've installed about 4 of these over the years in various cars and the work exremely well. You would need to buy the extra bit which allows you to use the car's speed sensor, as the basic kit relies on magnets mounted on the propshaft and a sensor. Overall, I would recommend it.
boodek is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 07:16 PM   #3
sfr rob
sfr rob's Avatar
so you reckon you would?
i was wondering how the cruise unit would work since it wouldnt be wired through the AU's ecu?
pretty easy set up i guess then?
Old 08-09-2005, 07:17 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
I fitted one to my boss's car back in 1998 and it was a piece of the proverbial.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 08-09-2005, 08:00 PM   #5
JC
JC's Avatar
Why not get one from the wreckers?
Ford Performance Club ACT
Old 08-09-2005, 08:37 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
I paid under $250 for a complete kit for an AU I Forte from a wrecker.. and this included new buttons.
installed it myself (dead easy) and works great.
deffinately go that route if u can.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 08-09-2005, 09:29 PM   #7
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
buy a secondhand kit ,
we supply kits with fitting instructions, i have fitted them myself takes about 30 minutes.
just remember to get the right kit for your car.
series 1 or series 2/3
auto or manual
6cyl or v8
sedan or wagon.
Darren
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2005, 12:14 AM   #8
sfr rob
sfr rob's Avatar
AU1 sedan
6 cyl
PM ME WITH A PRICE MATE PLEASE.
Old 09-09-2005, 12:23 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
I got mine from FTG autosalvage... Darren was also helpful in specifying what i'd need to do to make the sedan kit work on a wagon (they didnt have a wagon kit at the time)
Old 09-09-2005, 12:25 AM   #10
sfr rob
sfr rob's Avatar
what would the difference be?
anyway.
hopefully its a good price cause i AM buying a kit, but dont know where from yet..
rob
Old 09-09-2005, 12:45 AM   #11
JC
JC's Avatar
FTG would be the place to be. They've already given you some advice to help you out, so it would be the right thing to do to reciprocate by buying from them. Not that you should feel that you have to pay for advice - but I will be buying my Ford stuff from them.
Old 09-09-2005, 12:53 AM   #12
EFFalcon
Last warning
EFFalcon's Avatar
because the on/off switch is on the indicator stalk, the whole stalk assembly gets swapped to the cruise one.
wagon's have a switch for the rear wiper so fitting a sedan stalk wasnt going to work, had to take one of the stalks out of the assembly and swap it over, and add a few wires.
Old 09-09-2005, 01:03 AM   #13
JC
JC's Avatar
But on AU wagons, the rear wipers are controlled form the wiper stalk, not the indicator stalk.
Old 09-09-2005, 03:15 AM   #14
EFFalcon
Last warning
EFFalcon's Avatar
i know, but the cruise kit comes with the whole stalk and wiring assembly (both sides)
you simply slide the old one off, disconnect the wiring and put the new one on.
i had to actually pull it all apart and swap the stalks, which is a little bit trickier then just swapping the whole lot.
then i also had to add the wiring down the steering column.
Old 09-09-2005, 08:23 AM   #15
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Re: those Command Control units...
I have one in the ute, and it doesn't work what-so-ever. You can't turn it on, so I'm thinking that there's no power to it. I don't have a wiring diagram to have a look and see if everything connected properly too.
Carless
Old 09-09-2005, 05:14 PM   #16
sfr rob
sfr rob's Avatar
ok, i still dont know how much it will cost...
so when i find out i might pop down to FTG to pick up the kit!
Old 09-09-2005, 06:19 PM   #17
JC
JC's Avatar
Ring FTG - Ph(03) 9758 6900. I rang em today and ordered my complete BA Auto shifter mechanism - $150 plus postage.
Old 09-09-2005, 07:04 PM   #18
sfr rob
sfr rob's Avatar
wicked.. thats cheap isnt it?
are you putting that into your AU? that would be crazy!
saw the one the E-series bloke put into his car! very nice indeed.
good news on my body kit front.
i TOLD the guy he has to have it done by the end of the week, so if all goes to plan, i can drive my car again!!!!
its too late to call i will email darren and ask for some more info on the kit...
so if you happen to read this darren.. check your PM's.
cheers
Rob
Old 09-09-2005, 11:02 PM   #19
FTGAutosalvage
Commercial Sponsor
pm,s answered
but i remembered we DO have a kit down there for a series 1 sedan
i can make a kit up from the T series i will just need to buy in a 6cyl loom for you.
