Old 07-09-2005, 10:10 PM   #1
sickxr
Ford POWER!
sickxr's Avatar
Default HELP! Au XR6 manual stalls on ldle
This morning i went to start my car and my battery died. It was the factory one so i didnt think much of it and just replaced it. Tonight when i got it going again it wouldnt idle without stalling. I thought it may have been some crappy fuel so i filled it up with a tank of BP ulimate. After driving around for around 10mins it still does it. When i turn the AirCon off it wont stall but it will drop down to around 500rpm and then back up to 900rpm and back down again.
It is a AU2 XR6 Manual with 65k on the clock. Any ideas would be great, i guess the next thing would be to change the fuel filter? Or is it something with the computer?
Thanks
Chris
sickxr is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 11:17 PM   #2
EvilChief
Boost Addict
disconnect the battery again, let it off for about half an hour, then reconnect and go through the standrad relearn procedure (i think aufalcon.com has a write up on that), idle without ac, idle with ac, etc ...
give that a go ..
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 07-09-2005, 11:55 PM   #3
sfr rob
sfr rob's Avatar
yeop, and the ECU reset thing, ACTUALLY WORKS.. i had the same prob, but i have an auto, seemed to do the trick for me!
rob
Old 08-09-2005, 07:46 AM   #4
sickxr
Ford POWER!
sickxr's Avatar
Oh really its just as simple as that. I gotta drive it to work now (giving it a little bit of juice at the traffic lights) but i will give that a try tonight! Thanks
Chris
Old 08-09-2005, 09:14 AM   #5
sickxr
Ford POWER!
sickxr's Avatar
Ok so now im at work.. it only stalled twice and it ran pretty good but i still want to reset the ecu, but when i looked at aufalcon.com it says for a manual put it in gear.. I dont see how this would load the engine up. Do i need to slip the clutch with the handbreak on or do i just sit there with the car in gear with my foot on the clutch?
Thanks again.
Old 08-09-2005, 01:36 PM   #6
sfr rob
sfr rob's Avatar
hahah.... ONLY STALLED TWICE. .... GOLD.
from what i gather, i would say that you just have to depress the clutch an select a gear i think? dont know about riding the clutch though.
i hope you solve the problem though!
cheers
Rob
Old 08-09-2005, 06:49 PM   #7
justa6
justa6
justa6's Avatar
Just drive the thing, they are a learning computer and it will fix itself in no time.
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 10:16 PM   #8
sickxr
Ford POWER!
sickxr's Avatar
Well i reset the ecu..... and guess what!!! It worked! Thanks for your tips ppl
Old 09-09-2005, 11:51 AM   #9
spiteri
So let me get the sequence of events right. (pulled from aufalcon.com
- Take off the positive terminal lead
- When power is re-connected, start car and idle in this sequence
- 2 minutes idling with the transmission in gear (clutch down) and A/C on.
- 2 minutes idling with the transmission in gear (clutch down) and A/C off.
- 2 minutes idling with the transmission in neutral and A/C on.
- 2 minutes idling with the transmission in neutral and A/C off.
- Drive the car on the road, for at least 5 minutes under variable throttle positions.
Variable throttle positions relate to what?
spiteri is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2005, 02:28 PM   #10
Axle-F
AU - YEA YOU!
Axle-F's Avatar
As in use various styles of acceleration - slow acceleration, medium acc'n, high acc'n and a few in between...
actually my car in the shop for the very same problem - i'll try this and see if it works....
AU II XR6 VCT - JMM DEV3+
Axle-F is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2005, 03:06 PM   #11
sickxr
Ford POWER!
sickxr's Avatar
Yup i just did that and but for the 5min drive i just gave everything to it : now she is sweet as
Old 09-09-2005, 05:06 PM   #12
sfr rob
sfr rob's Avatar
EXCELLENT mate!
glad you solved the problem without taking it to a mechanic!
cheers
Rob
Old 09-09-2005, 07:28 PM   #13
Axle-F
AU - YEA YOU!
Axle-F's Avatar
Well my mechanic couldnt figure it out....
Can some enlighten me on how to actually disconnect the positive terminal??
I've just been trying for 20 minutes and the damn thing is stuck hard. I loosened the bolt and connector, but i can't actually pull off the cable - anyone have any suggestions?
Old 09-09-2005, 07:36 PM   #14
sfr rob
sfr rob's Avatar
really... that is weird as!
should be able to jiggle it around once you have loosened the bolts!
try some W/D spray if you still can get her off?? or use two screw drivers, lay one down on the battery and use the other one as lever and pop it off?????
Old 09-09-2005, 07:40 PM   #15
Axle-F
AU - YEA YOU!
Axle-F's Avatar
That could be a go-er...i'll give it a try now and report back lol!
Old 09-09-2005, 07:44 PM   #16
sfr rob
sfr rob's Avatar
remember you need to drain all power out of the ECU, apparently there is some power left in it even with the battery disconnected!
so you need to leave it off for 45 minutes or more then try the reset.
i ususally take it off over night if i can park the car in the garage then do it in the morning to make sure its really reset!
Old 09-09-2005, 07:53 PM   #17
Axle-F
AU - YEA YOU!
Axle-F's Avatar
There we go she popped off after using ure little lever trick. It was pretty firmly stuck in, which I think is because of some weird yellow spray the mechanic put on it when it was in - some anti corrosion stuff i guess.
Anyway i'll reset the ecu this evening cause i dont have a garage....god i hope it fixes the issue - the bloody car has gone to the mechanic 3 times this week!
Old 09-09-2005, 07:57 PM   #18
sfr rob
sfr rob's Avatar
good work mate,
yeah it is interesting, hope you get your car is ok too!
cheers,
off to the pub.
Rob
Old 10-09-2005, 09:41 PM   #19
Axle-F
AU - YEA YOU!
Axle-F's Avatar
resetted it last nigth and tonight for goood measure but no luck unfortunately...really starting to irritate me espcially in traffic.
off the the mechanics again! :
