Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 08-11-2024, 10:44 AM   #2161
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: Genuine Ford Parts
Originally Posted by gpierce View Post
It looks to me like the hose is part of the filler assembly in that pic and not separate (circled in my pic below). Good work Ford! What are they thinking. So yes 9034. Also is there a part number for the vent hose that goes to the tank (also circled)
Thanks!
Pic with circled parts:
https://ibb.co/bvyRYWH
Sent from my iPhone using Tapatalk
So for 9034 you have a choice of two, one for tub/body vehicle and one for tray/cab chassis vehicles, which one do you need?
As for the vent hose, no part number, looks like part of the tank only. Still available though.
GT
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 10:46 AM   #2162
gpierce
gpierce's Avatar
GT
Tub please and how much for the tank (I think it will hurt)
-15 Ford Falcon FGX XR8 Auto
-14 FPV Pursuit Ute #47 Auto
-12 FPV Pursuit Rspec #44 Manual
-11 FPV GS Ute #225 Manual
-10 FG XR8 Ute Manual
Sold
-06 BF XR8 Ute
-75 XB Falcon Coupe 351 GT replica
-73 Ford Mustang convertible 351
-20 Ford Mustang GT Convertible
gpierce is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 10:51 AM   #2163
GTLEGEND
Neck is $60 plus postage if need be. Tank $850 plus freight if need be also.
Old 08-11-2024, 06:06 PM   #2164
gpierce
gpierce's Avatar
Surprisingly reasonable on the filler tube. I have a fuel smell on hot days and I need to take it apart to first to see if that hose is bad. Doesn’t look it from the outside but never know. Will be in touch if I need it.
Sold
-06 BF XR8 Ute
Old 09-11-2024, 03:05 PM   #2165
gpierce
gpierce's Avatar
Hi GT. Are you able to confirm FG doors are the same part for Sedan and Ute? Pretty sure just the outer trim is different but the door shell is the same.
Sold
-06 BF XR8 Ute
Old 09-11-2024, 03:08 PM   #2166
GTLEGEND
Hey mate, yes front door body/skins are the same between sedan and ute.
Old 10-11-2024, 02:19 PM   #2167
mad2
Regular...with metamusal
Hi Legend
just want to confirm what loom is fitted to a BA XR6 [2004 - VIN 6FPAAAJGSW4D41745]
Thanks GT
Ps. was fitted with a premium ICC possibly S/Z and it does have the connection for the sunlight sensor. so i'm 'presuming' High class?.
mad2 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2024, 06:56 PM   #2168
GTLEGEND
Originally Posted by mad2 View Post
Hi Legend
Thanks GT
The catalogue unfortunately does not drill down to the exact loom for that VIN, it gives a choice of three options.
The pic of the part number you have are for cars with:
WIRING ASSY - INSTRUMENT PANEL, WITH AUDIO PEP PACK (4 DOOR SALOON, FAIRMONT/XR, LESS NAVIGATION SYSTEM OR GT/GT-P)
The other two choices are:
WIRING ASSY - INSTRUMENT PANEL, LESS AUDIO PEP PACK (4 DOOR SALOON, XR, LESS NAVIGATION SYSTEM)
or
WIRING ASSY - INSTRUMENT PANEL, WITH AUDIO PEP PACK, WITH CORNERING LAMP (4 DOOR SALOON, XT/FUTURA/XR/FAIRMONT, WITH NAVIGATION SYSTEM OR GT/GT-P OR F6)
Old 10-11-2024, 09:58 PM   #2169
mad2
or
Thanks GT
it was worth an ask. well i think we can rule out
as i'm pretty sure the cornering lights won't fit the XR front. it def had the premium sound & the sunlight sensor wiring [altho taped up under dash] & rear parcel cover ....... but that 'may have' been retro fitted .... who knows.
thanks for the reply.
Old 15-11-2024, 12:46 AM   #2170
crmpicco
crmpicco's Avatar
Hello again GTLEGEND,
Would you happen to have a glove box latch for a 2013 Ford Falcon FG MK2 XR6? russellw has pointed me in your direction on this thread
https://www.fordforums.com.au/showthread.php?t=11502386
The part number he has provided is BAF F06004 A1 LATCH
Many thanks
2013 Falcon XR6 FG MKII Kinetic Blue
Craig R Morton -WA-based Web Developer
crmpicco is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2024, 08:49 AM   #2171
GTLEGEND
Many thanks
Hi mate,
Should be able to get one, Warm Charcoal for $100 plus postage. If its Cashmere colour, then we need to do some searching.
It does not come with a lock. If you need a lock also, that is $35 extra.
Happy to organise for you if need be.
Old 15-11-2024, 10:15 AM   #2172
Neme
Needav8
Neme's Avatar
I don't suppose they still make OEM brake master cylinders for AU's?
Specifically 2002 AU3 XR8 manual if there's any difference
Back in the game with an '02 AUIII manual XR8
Neme is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2024, 02:28 PM   #2173
GTLEGEND
There are around 6 different brake Master Cylinders in the AU/AU3 range, unfortunately no longer available from Ford.
You may find some at some brake specialists as they were made by PBR.
Old 17-11-2024, 08:11 PM   #2174
bondy99
G'day GT,
I was replacing the brake light and indicator light on the rear of the AU2 tail light assembly.
Ford AU2 6 Cylinder Year 2000 sedan.
I noticed one of the bulb holders that twists onto the tail light to secure it has one of the locking piece broken off.
Are these still available?
If not are there any other types that would be suitable?
Thanks
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2024, 09:09 PM   #2175
There are this type https://www.ebay.com.au/itm/33310692...Bk9SR4isgpnnZA and https://www.ebay.com.au/itm/29206571...Bk9SR4isgpnnZA Supercheap can get them too: https://www.supercheapauto.com.au/p/...=en_AU&start=2
Old 17-11-2024, 09:35 PM   #2176
GTLEGEND
Originally Posted by bondy99 View Post
G'day GT,
Thanks
Original was ER13N454A, no longer available. Aussieblue has the aftermarket ones covered!
Old 19-11-2024, 09:55 PM   #2177
78xcgxl
78xcgxl's Avatar
Hi Gtlegend,
Can you still get FGX silver cruise control buttons if so what's the part no? Thanks
78xcgxl is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2024, 10:08 PM   #2178
GTLEGEND
Originally Posted by 78xcgxl View Post
Hi Gtlegend,
Hey there,
Yes believe you can, part number ER2Z9C888CA.
Can help you get if need be around the $200 mark plus postage if required.
Old 20-11-2024, 01:48 AM   #2179
crmpicco
crmpicco's Avatar
Hi mate,
Thanks for the offer mate. I’ve ended up gambling with a second hand glove box with latch off eBay. It looks fine and was $80 delivered so hopefully that turns up soon and does the job. If not I’ll be back in touch.
Old 21-11-2024, 12:55 PM   #2180
Blue_XR
Blue_XR's Avatar
Hi GTLegend,
I was wondering if there is any new stock floating around for a BF Handbrake cover in black? I'd also look at taking a leather one depending on what's available.
Thanks
YouTube channel: Modaufy Garage
https://www.youtube.com/c/ModaufyGarage
Blue_XR is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2024, 03:31 PM   #2181
GTLEGEND
Originally Posted by Blue_XR View Post
Hi GTLegend,
Thanks
Hi mate,
There were 5 different hand brake covers on BA/BF's, unfortunately none available through parts, you will need to search on line in the usual places but the below may be of help.
BA2760B1: Warm Charcoal Vinyl
BA2760B6D: Dark Stone Vinyl
BA2760F1: Warm Charcoal Leather
BA2760F6D: Dark Stone Leather
BA2760C1: Black Bench Seat
GT
Old 21-11-2024, 08:38 PM   #2182
Blue_XR
Blue_XR's Avatar
Hi mate,
GT
Thanks so much for checking. I’ll start searching for a good second hand one, I was hopeful there might be a new one out there somewhere.
Old 24-11-2024, 02:58 PM   #2183
FoxtrotGolfXray 5.0
FoxtrotGolfXray 5.0's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willingly providing technical info and documents, despite glitches.
G'day gt, finally getting around to getting a few little niggles in the ute sorted. After a P&A for the following, please:
* a brake light switch
* single gang window switch for the passenger side, and
* this little clip. Found on the rear, outboard side of the door card. Passenger side was OK, drivers side not so good. Suspect I'll need to get multiples, but happy to see what, if anything, you can come up either.
All to suit a 2013 fgii ecolpi ute, vin 6FPAAAJGCMDM28719
Postage to 3850, please.
Sing out if you need any further info.
Thanks for your assistance.
Labels are for jars, not for people.
Life is a journey, not a destination.
Daily: 2013 FGII EcoLPi in Winter White
Play: 2015 FG X XR8 in Emperor Show' N Shine thread
Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor
FoxtrotGolfXray 5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 24-11-2024, 05:02 PM   #2184
GTLEGEND
Hey mate,
Brake switch: Available $35
LHS door window switch: Available $39
Door trim clip: I have to check as there are two possible clips that the drawing is not really clear about. Either way they are $4 each.
Postage would be $11 for one or all of the items.
Get back to you on the clip.
GT
Old 24-11-2024, 05:16 PM   #2185
FoxtrotGolfXray 5.0
Thanks gt. I'll take one of each, either with or without the clip, depending on what you find, please.
I'll pm you my address.
Cheers.
Old 28-11-2024, 05:04 PM   #2186
Blue_XR
Blue_XR's Avatar
Hi GT legend,
Is it possible to get a factory rear parking sensor kit (including wiring and modules) for a BF Falcon?
Old 28-11-2024, 10:57 PM   #2187
GTLEGEND
Hi GT legend,
Hi mate,
Yes there was such a kit, for sedan it was BA13K236AC and wagons BAF2W13K236AA. I think they are both obsolete and would need to check if there are any still left around.
But in essence yes there were factory kits.
GT
Old 29-11-2024, 10:24 AM   #2188
Blue_XR
Blue_XR's Avatar
Hi mate,
GT
It would be great if there are any left in the parts bin.
Old 29-11-2024, 03:37 PM   #2189
GTLEGEND
Sorry no good mate, all gone from the formal sources, best keep an eye out on eBay, Market Place etc with the part numbers I provided.
Old 29-11-2024, 07:02 PM   #2190
Blue_XR
Blue_XR's Avatar
Appreciate you looking. Thanks
